FS: Works Bell GTP flip Up quick release
This new flip up quick disconnect from Works Bell Japan will allow you to quickly and easily remove your steering wheel. Requires Works Bell or Splash Hub.
The Rapfix GTC uses a Ball lock system design which will not come off during driving. No play whatsoever, this is the ORIGINAL! The piece is a cold forged aluminum body, which is track tested and proven by the top Japanese race drivers. Makes it easier to get in and out of your car.
This Flip-up GTC will only bolt to 6 bolt Momo patterned hubs or 12 bolt multipattern hubs. This is NOT a hub, you need to purchase the specific hub for your car in order to use this.
The height is 2.5" tall, so in some cases it may place the wheel to close to the driver. In cases as such, you may consider using a short hub instead of a standard length hub in order to lengthen the distance between the driver.
$420 Firm what i paid.
Turbo Dan
Mar 18, 2007 01:36 PM
