Auto lock, feature on Si???
Hey guys just wonderin' if we an auto lock feature on our FG2's???
I bought mine used and never got a honda manual with it. I ask this because I want to learn how to program the car to auto lock the doors once I start driving.
Holla back
Holla back
LOL its in the manual i have an 06 and until 2 weeks ago i never had it programmed it took me a few try to get it but i will see if i can post it up.
Don't you guys read, he said he bought his FG2 used and he didn't get a manual.
Here's the instructions:
Steps to set Auto-Lock modes on.
Turn Door lock ON for vehicles with manual transmission when the car reaches 9MPH/15KPH:
1) Close the driver's door.
2) Turn the ignition to the ON (II) position.
3) Set the Parking Brake.
4) Push and hold the front of the master door lock switch on the driver's door. You will hear a clicking sound, and after about 5 seconds, you will hear another clicking sound.
5) Release the switch, and then turn the ignition switch to the LOCK (0) position within 5 seconds.
Steps to set Auto-Unlock modes on.
To unlock the driver's door on manual vehicles when the ignition switch is out of the ON (II) position.
2) Turn the ignition switch to the ON (II) position.
3) Set the parking brake.
4) Push and hold the rear of the master door lock switch on the driver's door. You will hear a clicking sound, and after about 5 seconds, you will hear another clicking sound.
5) Release the switch, and turn the ignition switch to the LOCK (0) position within 5 seconds.
Disabling Door Lock Modes, both Automatic and Manual
1) Open the drivers door. [On Vehicles with automatic transmission, make sure the shift lever is in PARK (P).]
2) Turn the ignition switch to the ON [II] position.
Disabling Door Unlock Modes, both Automatic and Manual
* All settings of the Door Locks will retain setting even if the battery is disconnected.
Thank you guys for your help, honda-tech FTW, now I have to take my baby to the dealer because the damn sun roof won't flip open! It slides just fine but it wont tilt up.
theres a reset for the module that controls the sunroof....let me check if i find it....
here it is:
To reset the moonroof control unit, do these steps:
1. Turn the ignition swich OFF.
2. Press and hold the tilt switch, and turn the ignition switch ON.
3. Release the tilt switch, and turn the ignition switch OFF.
4. Repeat steps 2 and 3 four times.
5. Press and hold the moonroof open switch for 3 additional seconds after the moonroof is fully opened.
6. Press and hold the moonroof close switch for 3 additional seconds after the moonroof is fully closed (tilted).
7. Confirm that the moonroof control unit is reset by using the moonroof AUTO OPEN and AUTO CLOSE feature.
here it is:
