fabing up front end need help
Old Nov 18, 2007 | 04:27 PM
Day-DayC's Avatar
Default fabing up front end need help
i see in the drag car picture post pipes coming from the firewall how are you guy's doing this is it linking to the cagework or plates on the fire wall explaination or pictures would be a great help thanks
Old Nov 18, 2007 | 06:50 PM
Garage 808 Hatch's Avatar
Default Re: fabing up front end need help (Day-DayC)
to be done right, the bars should tie directly into the cage work
Old Nov 18, 2007 | 07:42 PM
bigTom's Avatar
the bars get welded to the a-pillar bars. one way or another you need to make a hole through the firewall or rain tray and run the tube through it. you can also use an existing hole if you want.
Old Nov 19, 2007 | 04:12 PM
Day-DayC's Avatar
Default Re: fabing up front end need help (bigTom)
thanks alot i was never to sure about it also seen it tie into the strut mounts so now i have a better idea
hyabusa hunter
Welding / Fabrication
41
Jan 24, 2011 04:54 PM
boosted d16z6
Mar 6, 2010 01:52 PM
munscher
Mar 30, 2004 10:58 AM
DamonBoost
Nov 27, 2001 04:00 PM
