Suspension & Brakes Theory, alignment, spring rates....
Limit Straps??
Old Nov 18, 2007 | 03:59 PM
hondadriver's Avatar
Default Limit Straps??
Whats up guys? I have adjustable coilovers and kyb agx shocks, and as you guys know with coilovers when you lift your car up, the spring is loose. Well i was wondering if there was a way to keep the shock from extending and keeping tight against the spring. I came across this spring limit strap. Its used for off roading vehicles, to prevent the shock from over extendiing. I did a search here on HT and I found a few topics about "Limit Straps" but they were only used by people who were drag racing trying to prevent rear squat. So I was wondering if someone has installed something like this and would it be worth it??
http://www.ultimateautoaccesso...62__1
I know on complete coilover assy's like the PIC ones , you can keep full tension on the spring and adjust the height but turning the entire shock up or down. cuz i know someone who has a set of these installed on their hatch, and when he jacked the car up the wheel come down like an inch or so, there was basically no shock droop. So is looseing the extra shock droop gonna affect anything????
Old Nov 18, 2007 | 04:35 PM
Targa250R's Avatar
be professional
Default Re: Limit Straps?? (hondadriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadriver &raquo;</TD></TR><TR><TD CLASS="quote">So is looseing the extra shock droop gonna affect anything????</TD></TR></TABLE>
Yes, depending on what you're doing with the car.
On an autocross car, you absolutely do not want to limit droop any more than you have to.
Realistically, why do you care that the spring comes loose at full droop? Is it causing you any problems? Does it really matter? Other than when you jack the car up or put it on a lift, is the suspension ever at full droop?
Old Nov 19, 2007 | 04:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I've heard of people drilling a couple of holes in the top hat and just using zip-ties to keep the springs against the top hat at all times.
Liquidgsr
Suspension & Brakes
Oct 1, 2010 04:28 AM
ssv05civic
Honda Civic (2001 - 2005)
Jan 14, 2007 05:52 AM
-=N.E.O.=-
Suspension & Brakes
Aug 29, 2006 05:20 PM
jbell
Suspension & Brakes
13
Sep 10, 2005 06:22 PM
slowestcivicever
Sep 9, 2002 10:22 AM
