B16 CRX crusing issues.
My car runs real crappy after about 10-15 min of crusing at constant rpm mainly 4-4,500. It misses real bad, sounds like loads of fuel being dumped into the cylinders. If I go full throttle its fine. It also drives normal if I let it idle for a few min or turn it off for a few. There is no CEL, the TPS is adjusted correctly. The ECU is also a PWO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">PW0 ecu is obd0 and requires 2 oxygen sesnors.
If you choose to run a single o2 then convert to obd1
THATS YOUR PROBLEM!</TD></TR></TABLE>
he knows what hes talkin about^
jdb2527
Aug 11, 2007 11:45 AM
vw eater
Feb 4, 2007 09:47 PM
b16crx0062004
20
Jan 24, 2005 07:46 PM
