H23 Turbo Dyno Results
Old Nov 18, 2007 | 01:24 PM
Neonxiii's Avatar
Default H23 Turbo Dyno Results
Hey everyone, here are my results from the dyno using a Dynapack.
Here was the 6psi Baseline.
here is the final run on 6psi after the tune was complete. this was after a good deal of heatsoak, so keep in mind that if we had done a cold run with this tune, it would have been at least another 10hp/10tq higher. it took me a bit to realise why i couldnt get rid of the dip in the beginning around 4000rpm's, but that is because i am using a p06 ecu that does not have control of the secondary butterflies. so when i did the initial install, i connected the vacuum line for the secondaries' diaphragm directly to the manifold. which means instead of them staying closed then opening around 4800-5k rpms, they are now controlled by manifold pressure instead of rpm. which means that the secondaries will be open at all times in boost. which equates to a loss in power in bottom end due to less efficiency of the manifold (runner length and diameter). it is definitely a noticible loss on the chart, portrayed by that nice large dip lol, but its really not that much of a difference compared to what it would be if the butterflies operated according to rpm. so here it is, final tune on 6psi in my 100% bone stock h23 heatsoaked and with the secondaries open at all times in boost:
Hoped you guys enjoyed this
Old Nov 18, 2007 | 02:00 PM
preludestud11's Avatar
Default Re: H23 Turbo Dyno Results (Neonxiii)
looks good. gotta love the torque of the h23. and pics of the motor?
Old Nov 18, 2007 | 02:09 PM
Neonxiii's Avatar
Default Re: H23 Turbo Dyno Results (preludestud11)
Old Jan 23, 2008 | 12:53 AM
Slomies's Avatar
Your setup looks very nice! I can't wait to start getting parts to turbo my h23 5th gen Accord.
EDIT: you CAN add the function to your p06 to control the secondary butterflies. That's what I did with mine ...
Old Jan 23, 2008 | 10:27 AM
.PLUMMM's Avatar
Gotta love the torque numbers that come along with the H-series. Torque numbers are just as high as the whp numbers lol Looks good
Old Jan 23, 2008 | 10:32 AM
GTibunny16v's Avatar
What turbo are you running? Looks like the hot side is a bit too small by the way the torque drops so fast.
Old Jan 23, 2008 | 12:14 PM
93CX's Avatar
Default Re: H23 Turbo Dyno Results (GTibunny16v)
Yeah get a bigger snail for that
PirateMcFred
Mar 13, 2024 08:19 PM
ItsSlowYo
Feb 28, 2006 06:12 AM
iCe_2x
Nov 17, 2005 09:02 PM
93H22ACX
Nov 18, 2004 06:27 PM
petrv
Jan 24, 2003 07:47 AM
