No cluster lights or tail lights
Old Nov 18, 2007 | 11:27 AM
moyospeed's Avatar
Default No cluster lights or tail lights
A friend of mine owns a 1991 EF hatch all stock no swaps or nothing. Recently his Intrument cluster lights went out and so did his tail lights. And the tail light fuse keeps blowing, as soon as we put a new one in. any help plz?
Old Nov 18, 2007 | 11:49 AM
socalrex88's Avatar
Default Re: No cluster lights or tail lights (moyospeed)
what fuse amperage are you using? im pretty sure its a 10 but try a higher amp fuse, and if not working try a lower one.
thats all i could do good luck!
Old Nov 18, 2007 | 12:30 PM
manicmechanic's Avatar
sounds to me like you have a short some where. I wouldn't use a higher amp fuse more of a risk of burning wires up. not a good idea at all. always use the specified amp fuse that circuit calls for. have you got an electric wiring dirgram or have access to one? with that it should help you get to the bottom of why that fuse keeps blowing.
Old Nov 18, 2007 | 01:23 PM
janz3n's Avatar
Default Re: No cluster lights or tail lights (manicmechanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalrex88 &raquo;</TD></TR><TR><TD CLASS="quote">what fuse amperage are you using? im pretty sure its a 10 but try a higher amp fuse, and if not working try a lower one.
thats all i could do good luck!</TD></TR></TABLE>
thats a dumb suggestion.
this happened to me aswell.. when someone backed in to my car they broke the corner light and the bulb so i took the bulb out and left the light in and im pretty sure that cuased my short. but even after i replaced the light it would still do it but not as often. ended up running a wire from one of the head light fuses to the tail lights. but now everything works fine and i dont blow fuses. you coulda pinched a wire somewhere
crxaddikt
13
Jul 28, 2010 01:07 PM
xtreme26
Oct 28, 2008 07:42 PM
nick1989
Aug 27, 2007 01:41 PM
EJ1_203
Apr 13, 2005 11:46 PM
1sikcoupe
10
May 7, 2004 03:23 PM
