1996 honda accord ex Alternator remove..
sooo im having problems with my cAR... been jumping it... i tryed new battery, and still same... it dies once i shut off the car... so im assuming alternator... car doesnt turn over or anything, seems there is no juice or anything.
im having problems getting the alternator out of my car... I got all the bolts i beilve except the one neer the Belt... anyone have a clue how to get to this? i checked my repair manual but doesnt say much... im soooo lost...need help asap!
thanks n advance..
P.s... this is for a AUtomatic accord... not stick if it makes a difference.
thanks n advance..
yea the last bolt people usually take out is the one located under the alternator,you would just have to take out the bolt from the screw-size i forgot-and once out hold your alt if one hand and screw with the other and play with it left to right up and down and you should be able to take out that screw,as for your alt. the way i check if it is working or not,with your accord engine on go under the hood and disconnect the positive +side of the battery,if the accord dies out then it is your alt.if it is still on then your alt.is alright the problem could be somewhere else
khansen
Mar 17, 2014 11:03 AM
