Suspension & Brakes Theory, alignment, spring rates....
Help GCs.
Old Nov 18, 2007 | 10:38 AM
NOman0608's Avatar
Default Help GCs.
Were tryin' to install Koni yellows and GC coilovers on my friends Del sol.
But they didn't come with any assembley instructions.
I have a few questions:
1) What parts will I need to remove from the stock shocks / springs to put on the konis
2) Which peices in the below picture are used, and in what order do I put them togeather
Everything on the far right side of the picture - Washers, nuts etc, has double what you see. I only opened one package.
Thanks for your help!!! If you can help please respond ASAP. Parts store closes eairly on Sunday.
Old Nov 18, 2007 | 01:26 PM
civicnoob's Avatar
Default Re: Help GCs. (NOman0608)
if your gc's sleeves are made for koni shocks you do not need the koni snap ring or the koni spring holders and the thin washer
plastic clip
bumpstops
thick washer
gc sleeve and srpings
spring isolators
then put that metal sleeve in your original bushings
oem shock hat
washer facing up
one of the bolts tighten it all the way
second bolt tighten to the other bolt
if you need more help search for koni and ground control
Modified by civicnoob at 2:48 PM 11/18/2007
Modified by civicnoob at 2:49 PM 11/18/2007
Old Nov 18, 2007 | 07:50 PM
NOman0608's Avatar
Default Re: Help GCs. (civicnoob)
thanks for the help..
we already had gotten it figured out though..
Old Nov 19, 2007 | 04:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Check the thread in my sig and also RJ's thread stickied at the top and make sure you got everything on correctly.
jdm_94
Jul 13, 2009 12:43 PM
street_ride14
Suspension & Brakes
Jan 2, 2008 06:30 PM
MrCivic03
Honda S2000
Jun 22, 2005 04:01 PM
SmasonGSR
Mar 22, 2004 12:26 PM
Shoe
May 22, 2002 06:07 AM
