Torqing Cam Gears
Old Nov 18, 2007 | 06:12 AM
kornerk12's Avatar
Default Torqing Cam Gears
I believe according to Skunk2 they want to to go 30 ft lbs on them along with some loctite. And they specifically say not to use an impact on them. How are you supposed to torque them though ? Anyone have any tricks on holding them when tightening the cam gear ? I would think a vise with a rag around the cam would be very bad so I really am not sure ? Or is using an impact gun ok if your careful ?
Old Nov 18, 2007 | 06:20 AM
mgags7's Avatar
get them on as tight as you can now, then once everything is together and the timing belt is on, use something to hold the gear still, and then torque them
Old Nov 18, 2007 | 06:35 AM
gogunkergorilla's Avatar
Default Re: Torqing Cam Gears (kornerk12)
Tighten them by hand, set the timing, install the belt and tensioner, use a crankpulley holder, push the timing belt against the cam gear with one hand and torque with the other.
Old Nov 18, 2007 | 06:51 AM
mgags7's Avatar
Pushing on the belt isn't enough, like I said I recommend holding the car gear.
Old Nov 18, 2007 | 07:02 AM
Default Re: (mgags7)
Holding the belt is more than enough for 30 lb-ft. Whatever you do don't go jamming screw drivers or whatever into your cam gears.
Old Nov 18, 2007 | 07:13 AM
v4lu3s's Avatar
RTFM
never ever use an impact gun to install or remove cam gear bolts, that can easily break the cam.
I just put the gear on hand tight, install the timing belt, and then line it up and put allen keys through the spray bars through the cam holes so they are both locked and that is easy enough.
Old Nov 18, 2007 | 07:26 AM
PirateMcFred's Avatar
Default Re: (v4lu3s)
Nail a chunk of old timing belt to a 2x4 and use that to hold the cam gear.
Old Nov 18, 2007 | 07:38 AM
Acidcrakker's Avatar
Default Re: (PirateMcFred)
Now thats ghetto<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Nail a chunk of old timing belt to a 2x4 and use that to hold the cam gear.</TD></TR></TABLE>
Old Nov 18, 2007 | 10:15 AM
117's Avatar
117
And what method do you use?
Old Nov 18, 2007 | 02:35 PM
SikB's Avatar
Default Re: (117)
how about using a strap wrench on the shaft or gear?
Old Nov 18, 2007 | 04:02 PM
Default Re: (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Now thats ghetto</TD></TR></TABLE>
lol. Have you seen my POS hybrid engine? It has less than $1000 invested and it makes 200whp/183tq. It's totally ghetto. If you want to go get some $200 snap-on wrench be my guest. I spent my money on another car not tools.
Pirate
Old Nov 18, 2007 | 04:20 PM
Ha, Ive heard about it, and might of read about the first page of it, but that is way past my current skill level.
But hey I know about these tools being exspensive. I just did my swap the other week, and spent about 500 bucks on diffrent tools. They get exspensive. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">
Pirate</TD></TR></TABLE>
Old Nov 18, 2007 | 06:15 PM
mgags7's Avatar
Default Re: (gogunkergorilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogunkergorilla &raquo;</TD></TR><TR><TD CLASS="quote">Holding the belt is more than enough for 30 lb-ft. Whatever you do don't go jamming screw drivers or whatever into your cam gears. </TD></TR></TABLE>
I like to wrap them in rags.
Risking jumping teeth versus overconfidence. You make the decision.
Old Jan 6, 2008 | 03:29 PM
cpforyou's Avatar
30 Ft-LBS?
Wowzers... the ones I use have specs to use only 15 FT-LBS. Just in case my torque wrench isn't accurate, put it at 16 and it works fine.
EJ8tunerman
Jun 21, 2005 04:35 PM
HamiltonRex
Nov 13, 2004 05:50 PM
EK4 hatchback
May 31, 2004 08:45 PM
Lightning Lover.
Nov 30, 2003 06:46 PM
baonest1
Dec 17, 2002 02:40 PM
