Picture Of Cam Seals Installed (Not Cam Cap)
Old Nov 18, 2007 | 06:08 AM
kornerk12's Avatar
Default Picture Of Cam Seals Installed (Not Cam Cap)
Does anyone have a picture of cam seals installed installed ? Im not sure how far off the cam gear its supposed to sit. Also where do you grease and what kind of grease ?
Old Nov 18, 2007 | 06:19 AM
mgags7's Avatar
You should use a good synthetic grease on the inner lip of the seal where it rides the camshaft, so that the seal doesn't burn when you first start up and no oil is there yet.
They sit all the way back into a recess, so you really can't push them in too far...
Old Nov 18, 2007 | 07:38 AM
gogunkergorilla's Avatar
Default Re: Picture Of Cam Seals Installed (kornerk12)
Hylomar grease if you can find it. Wipe the area down with brake cleaner first and put some on the camshaft and the inner lip of the seal. They should sit slightly recessed.
Old Nov 18, 2007 | 07:43 PM
m00nr0ck Si's Avatar
Default Re: Picture Of Cam Seals Installed (gogunkergorilla)
Honda OEM cam seals come with little beads of grease on them...I just put new ones in my H23 tonight ....
Old Nov 22, 2007 | 02:59 PM
kornerk12's Avatar
Default Re: Picture Of Cam Seals Installed (m00nr0ck Si)
im asking because mine are leaking and im not sure how to install new ones. Like where they are supposed to sit. Pictures would help more i think.
Old Nov 22, 2007 | 04:42 PM
117's Avatar
117
I think they only fit in one position along the cam cap. I usually install cam seals with Hondabond to, which helps prevent leaking.
Old Nov 22, 2007 | 07:01 PM
kornerk12's Avatar
Default Re: (117)
hmmm so did you grease them also ? Where did you apply the hondabond ?
I still dont really know how far back they should go. Should I just push them as far as i can ? Obviously without forcing them or distorting the seal.
Old Nov 22, 2007 | 11:58 PM
98vtec's Avatar
moderator emeritus
Default Re: (kornerk12)
i dont understand what you arent understanding....these guys are telling you how to put them in....
Old Nov 23, 2007 | 01:02 AM
117's Avatar
117
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm so did you grease them also ?</TD></TR></TABLE>
As someone has already stated, they come with grease on them from the factory. If you're reusing them, then regrease them, if they're new, they already have grease on them. Make sense?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">Where did you apply the hondabond ?</TD></TR></TABLE>
Well, there are only two surfaces in contact with anything. The OD contacts the head, and the ID contacts the cam. Take a wild guess on which surface the Hondabond goes. Hint: It's not the surface that seals something that's rotating!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">I still dont really know how far back they should go. Should I just push them as far as i can ? Obviously without forcing them or distorting the seal. </TD></TR></TABLE>
Are we reading the same posts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">They sit all the way back into a recess, so you really can't push them in too far...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogunkergorilla &raquo;</TD></TR><TR><TD CLASS="quote">They should sit slightly recessed.</TD></TR></TABLE>
Have you bothered to actually look at the cam cap and head with the seal installed? It's not like you have to press the seal in since the cam cap comes off the head. My guess is that you haven't even bothered to look at the damn thing. Look at it and study it, then get back to us if you still don't understand what to do.
I really don't mind helping people, but I really feel that you're in over your head if you can't see how to install the cam seals. Are you actually building this engine yourself without any supervision?
Modified by 117 at 9:52 AM 11/23/2007
Old Nov 23, 2007 | 06:29 AM
mgags7's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">Take a wild guess on which surface the Hondabond goes. Hint: It's not the surface that's moving! </TD></TR></TABLE>
Sounds like somebody needs a hug and a turkey sandwich
OP:
That is all the helms says about installing them. When they normally go into pages of detail on everything but leave one sentence for this, it has got to be very simple.
Old Nov 23, 2007 | 06:41 AM
117's Avatar
117
Default Re: (mgags7)
I'm all for helping people, but this is getting a little ridiculous. Not the question, but the fact that he gets 3 or 4 fairly clear answers and either doesn't believe them or just doesn't understand!
1BADEGDC2
Nov 8, 2008 11:45 AM
TheWalrus
Jan 30, 2006 05:47 AM
blueintegra90
May 18, 2004 12:47 PM
