F22 Clutch bell housing bolt up with H22 transmission bell housing?
OK so tonight after what seems to be a freak accident the differential in my H22 transmission broke something off it and blew a huge chunk out of my H22 transmission clutch bell housing, but I am wonder if I can use a F22 clutch bell housing in its place considering finding a cheap F22A1 transmission is alot easier then finding a cheap H22 transmission just for the clutch bell housing!
So will a F22A1 Clutch bell housing bolt up with H22A1 transmission bell housing?
I don’t have an Accord transmission I have a H22 transmission and the differential some how broke a small piece off and shot through the clutch bell housing! And I dont feel like spending an arm and a leg for a H22 transmission when the gearing in mine is still good! i just would need to replace the Final gear and diff. and clutch bell housing!!!!
I am not following you here bro!
I know for a fact the clutch bell housing and gear housing on a H series and an F series can be pull apart from each other!!!???
You’re making no sense here with your reply…
I am not asking if the housing cant be pull apart that’s basic transmission knowledge that they can other wise you could not do service on the gearing of the transmission!
I am asking if the H22 gear bell housing can be bolted to a F22 clutch bell housing?
sorry for trying to help, obviously I misunderstood which trans you had... dont implode or have a spike in blood pressure over it.
you could put your h series transmission internals into an f series transmission casing... they are virtually identical (the only difference is the gearing to my knowledge) but as for mixing housing halfs... I dont know 100% for sure if you can mix and match the 2 casings.
hopefully someone else will translate that and help you out since I apparently dont speak english or make any sense (moday mornings are fun like that I guess).
edit'd: simplified and removed rant.
Modified by twkdCD595 at 9:12 AM 11/19/2007
