Long ago Dyno's..........used to rule the earth???
Old Nov 17, 2007 | 09:00 PM
IntegraTionR's Avatar
Default Long ago Dyno's..........used to rule the earth???
Old Nov 17, 2007 | 09:15 PM
GO-FIGHT-KILL's Avatar
Specifications?
Old Nov 17, 2007 | 10:54 PM
oldskool teggy's Avatar
Default Re: Long ago Dyno's..........used to rule the earth??? (IntegraTionR)
how come it says this dyno is form mar 2006?
Old Nov 18, 2007 | 01:03 AM
fourcsan's Avatar
* B A N N E D *
because thats when they ruled the earth. right on man! ...sometimes you jus need a dyno.
Old Nov 18, 2007 | 06:28 AM
Dave_B's Avatar
Also... according to that chart...
It's FW HP, not WHP...
Old Nov 18, 2007 | 07:54 AM
Its just a mistake on the title because he had to print my dyno chart from another computer!
Old Nov 18, 2007 | 09:23 AM
mtber's Avatar
Default Re: (IntegraTionR)
Dynapack flywheel whp ftw lol
Old Nov 18, 2007 | 09:50 AM
George Knighton's Avatar
H-T Order of Merit
Not sure what the correction factor's about. Must've been a weird weather day.
Old Nov 20, 2007 | 11:21 AM
GUILOTINE's Avatar
Kill Gil
It's actually HP and the hubs, not flywheel
Old Nov 20, 2007 | 11:24 AM
92TypeR's Avatar
FSAE
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">It's actually HP and the hubs, not flywheel</TD></TR></TABLE>
Sort of.
The power is measured at the hub, but DynaPack software uses correction values for flywheel HP. So the power you see on the charts is flywheel HP.
Old Nov 20, 2007 | 11:40 AM
GUILOTINE's Avatar
Kill Gil
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
Sort of.
The power is measured at the hub, but DynaPack software uses correction values for flywheel HP. So the power you see on the charts is flywheel HP.</TD></TR></TABLE>
Not at CAT. That is actual Hub HP
Old Nov 20, 2007 | 11:43 AM
Dave_B's Avatar
Says Fly Wheel HP on the chart.
Old Nov 20, 2007 | 11:50 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Sort of.
That is true only if you enter a Transmission Correction Factor.
We do not use that, so the number you see is hub HP/torque.
TCF=1.0 on all of our dyno charts.
Old Nov 20, 2007 | 12:15 PM
92TypeR's Avatar
FSAE
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
TCF=1.0 on all of our dyno charts.</TD></TR></TABLE>
I see, my bad. That was the explaination I recieved from a local DynaPack tuner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Says Fly Wheel HP on the chart. </TD></TR></TABLE>
Chart titles FTMFL
Old Nov 20, 2007 | 12:20 PM
Dave_B's Avatar
Marshall...
So are you saying it's not rated at FW HP? Shows FW Tq and FW HP.
Old Nov 20, 2007 | 01:46 PM
92TypeR's Avatar
FSAE
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Marshall...
So are you saying it's not rated at FW HP? Shows FW Tq and FW HP.</TD></TR></TABLE>
If that chart was taken from a dynapack run at Church's, from what Todd said, the numbers are taken as hub power. If that is the case, the chart titles were not changed to reflect what the numbers actually are.
The dynapack I've been to locally uses the correction factor for flywheel HP, that is why I stated what I did earlier.
This is why dyno's suck.
Old Nov 20, 2007 | 04:07 PM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">This is why dyno's suck. </TD></TR></TABLE>
couldn't agree more!
b20beast83
41
Mar 7, 2009 02:47 AM
igo4bmx
May 18, 2006 10:21 AM
Marlon88
Mar 22, 2005 01:04 PM
cpforyou
Jul 13, 2003 11:21 AM
Cova85
Nov 12, 2002 01:34 PM
