type r cluster
just curious if i swap a type r cluster into my ep3 will it still show original miles or the miles that the cluster has on it. I didnt know if electronic odometers were like normal odometers or not. thanks for the help
Is the EP3 swapped to an a2 or do you just want the higher max speed readout? The gearing on the Si tranny will not push it past what the Si speedo registers (144) and it will not rev to anywhere near 9K, so I was just curious...
