Re-wiring of stock B16 Map Sensor connector plug from a GM 3 bar
HT's been good at answering my recent questions regarding my cars transformation back to almost stock form, I got another for you guys.
Right now I have a GM 3 bar map sensor on my B16. I do not have the connector plug for the stock map sensor anymore.
Once I find one and buy it, what wires need to be spliced/put where into the connector plug. I know Hondata has a diagram of how to wire the ABC part of the GM 3bar, but I'm not sure how to wire back the stock connector because mine was never spliced, it was just removed.
Also, does anyone have one for sale with some wire still in the connector? That would make it easier to splice. Or does anyone know how much one of these runs at the dealership?
Thanks for you help again, it's appreciated.
I would just go to the junkyard and clip a the map sensor harness with a bunch of wire still left on it so its easier to splice all honda map sensor harnesses are the same just make sure its from the same era of obd, but I think obd1 and obd2 map sensor connectors are the same. How is the gm one wired up? Did they completely de-pin it from the ecu?
No, it is spliced into the original wires I believe - off the top of my head I can't remember though. I'll check when I get off work, maybe get a picture. If it is still wired to the original map sensor wires can I just splice the originals back to originals?
Good idea with the junkyard though.
K i l l a B e e.
May 30, 2009 02:28 PM
