ls vtec swap
Old Nov 17, 2007 | 03:29 PM
the_big_dl86's Avatar
Default ls vtec swap
hey im buildin a ls vtec and was thinking about going with gsr cams, pistons and rods.and its gonna be na.anyone know if the gsr internals are good for the ls vtec setup?
Old Nov 17, 2007 | 09:11 PM
Fat Head
Guest
Posts: n/a
Default Re: ls vtec swap (the_big_dl86)
ok and.
Old Nov 17, 2007 | 10:05 PM
ToeJam's Avatar
Ls crank=Ls rods or custom rods/pistons
search ls vtec
Old Nov 19, 2007 | 07:34 AM
Default Re: ls vtec swap (ToeJam)
so the gsr rods wont go on the ls crank?
Old Nov 19, 2007 | 10:51 AM
and can i bolt up a gsr throttle body on the b16 intake manifold?and what size are the oem throttle bodies both b16 and gsr?please help!?
Modified by the_big_dl86 at 8:20 AM 11/20/2007
Old Nov 20, 2007 | 05:59 AM
HYBRDcrx's Avatar
LS crank and rods unless you want to buy custom rods$$$
Old Nov 20, 2007 | 10:02 AM
K2sInteg98's Avatar
Default Re: ls vtec swap (HYBRDcrx)
no gsr rods wont fit on an ls crack. the point of doing ls vtec is using the ls crank because of its longer stroke.
k e v i n
Jul 17, 2006 12:25 PM
crxsirvtec
Jan 26, 2004 06:20 AM
ianmclain
Jan 10, 2003 07:59 PM
