1997 civic, after a front end accident, lights flicker a bit and speedo is all random
Old Nov 17, 2007 | 03:28 PM
aleks77's Avatar
Default 1997 civic, after a front end accident, lights flicker a bit and speedo is all random
my friend bought a 97 civic for $500 front end smashed a bit (bumper, rad support upper, rebar, hood) nothin super major, fixed it, runs good, but the engine light is on, the speedo needle is just totally random goes up down up down on its own, and the lights flicker when giving gas....what can this be? Thanks for any info!!
Old Nov 18, 2007 | 01:12 PM
aleks77's Avatar
anyone? can i reset the ecu somehow? the speedo is crazy all over the place
Old Nov 18, 2007 | 01:22 PM
Syndacate's Avatar
Default Re: (aleks77)
You can reset the ECU just by leaving the battery unplugged for a few minutes, though that's not your problem.
The lights flickering when you giving it gas is probably due to the alternator being bad or going out the door. As for the speedo needle totally going random that's probably an effect of your VSS (vehicle speed sensor) going down or a short in the wires going to it, or either of the O2 sensor heaters.
The alternator, both O2 sensor heaters, and the VSS are linked on one harness, if there's a short in that harness, you'll have problems in all of those components, and all of those components seem to be tied to the problems you're having.
Pull the codes from your ECU, see which ones you're throwing, that will help diagnose the problem better, though I'd say you're probably looking at a short in that harness.
Here's how to pull your codes:
https://honda-tech.com/zerothread/1901557
utn
Honda Civic (2001 - 2005)
Oct 1, 2009 02:16 PM
98CivicTech
17
Apr 27, 2009 06:49 PM
Lewis7789
Jun 12, 2007 02:22 PM
DammitDan
Apr 10, 2007 09:58 AM
ringooo
Sep 11, 2006 11:44 AM
