1995 Civic LX problem
Old Nov 17, 2007 | 01:55 PM
mr_boondoggle's Avatar
Default 1995 Civic LX problem
My daughter's car overheats and shots coolent out the overflow hose.
Radiator does not leak.
Cooling Fan Operates normally.
Thermostat operates normally,
the oil is clean-no coolant.
the coolant is clean-no oil.
The coolant gets so hot it steams into the overflow bottle. A couple of times, it blew the over-flow hose off and coolant gussed out.
The engine will over heat periodically.
The engine hesitates, occassionally, when accellerating from a dead stop.
As you drive, the temperature of the heater varies between hot and cold.
If you start the engine with the radiator cap off, coolant gusses upward like a fire hose.
Help me....I'm thinking blown head gaskets or worse.
Modified by mr_boondoggle at 3:39 PM 11/17/2007
WaryDriver
26
Jan 8, 2017 09:54 PM
Thatfrogguy71
Honda Civic (2001 - 2005)
May 2, 2016 05:15 PM
grimview
Jul 22, 2013 03:32 PM
b00sted4dr
Oct 11, 2006 11:35 AM
cnycivic
Mar 28, 2004 07:55 PM
