Crx w/ B16 having emissions problem Portland, Or
So I bought a 89 CRX w/ a 1st gen B16a.
Mods are Intake, Header, Exhaust, CTR cams, Cam gears, MSD 6A, MSD Cap, Blaster SS External coil, and a stock PR3 ECU.
So here is the problem,
The Limit on H/C in Oregon is 220, but I went to DEQ and I blew a 1505... What can I do to reduce the H/C??? What have you other EF B16 guys done to pass emissions???
I need help bad...
I need help bad...
So What should I do about this??? could I get pass emissions w/ a 1.8 or 2.0L block??? Would like to just keep the B16 temporarily though...
Is there a reason as to why the JDM B16 will not pass???
Sorry for all the questions, but I come from driving Sentra SE-R's and we never had a Problem w/ emissions when swapping a stock SR20DET in there... but o well...
Help very appreciated...
nope, we can pretty much swap whatever and no visual check or anything like that... we roll up and idle for 1min, then rev 2500 rpms for 1 min and if the motor rund good you pass...
also some parts of the states doesn't have emissions testing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">JDM b16's do not pass emissions</TD></TR></TABLE>
HAHAAHHAHHAAAA......
What did you smoke?
If the emission stuff is hooked up, and the motor is healthy, and not cammed out....itll pass just like any other motor......
How did you come up with that one?
What did you smoke?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">
What did you smoke?
How did you come up with that one?</TD></TR></TABLE>
exactly what i was thinking.
here in ohio, its hard as hell to pass emmisions. but i kept all my smog stuff hooked up and i passed with my first gen jdm b16. wtf
What did you smoke?
What smog stuff are you guys talking about??? are you guys talking about USDM Intake manifolds and such??? EGR???
If so what car did you get the manifolds from??? DEL SOL, CIVIC SI, Or the R's???
Also are the CTR Cams too much for emissions??? should I swap the stock B16 cams in and then go to emissions???
Also would it help if I went for a OBD-0-1 conversion with a p28 and lean the expletive outta the car???
O2 is new, spark plugs are new... i was thinking maybe there is a bunch of carbon build up and maybe the cat maybe bad...
Because before i bought the car it had been sitting for about 4 years... but I threw a new battery in there and it fired up right away... you think the injectors maybe clogged or leaky???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonknee »</TD></TR><TR><TD CLASS="quote">i say u get rid of msd crap. waste of money</TD></TR></TABLE>
X2...
New plugs, rotor, cap, wires, (all honda oem)....
new 02 sensor(s)
Make sure all the old gas is gone.....No egr on civics back then.
Run a can of BG-44K through it. GET THAT SPECIFIC BRAND.
New cat. OEM if possible.
Switching to 0BD1 if possible and get someone to tune it for you that knows their **** on a dyno.
Then come back and post results.
X2...
new 02 sensor(s)
Get a new cat set your cams to 0 if you have cam gears and adjust your
timing mabe even retard it 2 deg. My jdm type r swap passed first try
when I had a ls swap it took 20 times. Make sure the cat is warm drive
like a hour or so. You can goto Darrels muffler on 82nd for a cat it will
run you about 120 installed. good luck
Paying extra doesn't quite work like that...
maybe just need to buy another cat... will shoot some results after i am done
What did you smoke?
Well i meant a jdm motor from japan because it doens't have "emission stuff"
What did you smoke?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">JDM b16's do not pass emissions</TD></TR></TABLE> Yes they do mine passed with flying colors.
