Prelude won't stay started
Old Nov 17, 2007 | 06:45 AM
Bernod's Avatar
Default Prelude won't stay started
I bought a 95 Prelude a couple months ago. It's a nice car. I did a few upgrades to it. Megan Racing exhaust and a custom cold air intake. It's ok because I only drive the car to work. But I have this problem that just came up. The car will start but turn off as soon as I let the key go but if I cold the key in the on position it will stay runnung. I read the forum and I thought it may be the main relay but I went to the Honda dealer and said it's a part gone bad on my ignition switch. Anyone had this problem before?
Old Nov 17, 2007 | 06:50 AM
manbearpig's Avatar
Default Re: Prelude won't stay started (Bernod)
One of my buddy's car was doing this a few weeks ago, we got the ignition out of my parts car, and he actually only needed the "cap" or "plug" on the end of the ignition cylinder. It has a bundle of wires attached to it, and the other end has 2 plugs, one to the fuse box and the other goes somewhere else, he changed just that and got to keep his ignition and it fixed his problem. Hope that helps
Old Nov 17, 2007 | 07:28 AM
slamdlude's Avatar
Default Re: Prelude won't stay started (manbearpig)
You need the electrical piece on the back of the ignition cylinder. You can get one from honda for about 40 bucks.
Old Nov 17, 2007 | 09:47 AM
Bernod's Avatar
Default Re: Prelude won't stay started (slamdlude)
Thanks fellaz The part won't be here until Tuesday 20 Nov. I'll keep you posted on what happens. I was just in Montgomrey 2 wks ago! I have a friend who lives there we went to JenningsGP to race our motorcycles.
Old Nov 22, 2007 | 07:41 AM
Bernod's Avatar
I got the $60 switch from Honda. It was a pain in the butt but I got it working and I have no issues! Thanks for the info. Now my computer has crashed! So, I have to get investigate that.
Old Nov 22, 2007 | 07:46 AM
hazeleyes76's Avatar
this happened to me before..it was my ignition switch
Old Dec 1, 2007 | 08:25 PM
Bernod's Avatar
Update the car is still running fine. New mystery has anyone had the mysterious clutch reservoir leakage? I put fluid in the clutch reservoir at least once a week.
Old Dec 1, 2007 | 08:41 PM
Hawkze_2.3's Avatar
Default Re: (Bernod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bernod &raquo;</TD></TR><TR><TD CLASS="quote">Update the car is still running fine. New mystery has anyone had the mysterious clutch reservoir leakage? I put fluid in the clutch reservoir at least once a week.</TD></TR></TABLE>
Search the clutch line for leaks...it's probably coming from the clutch damper mounted to the passenger side frame rail.
Old Dec 1, 2007 | 09:15 PM
blackh23's Avatar
yeah, it happend to my prelude before too. I would start it and it would shut off if let go of the key. Bad ignition switch. I didn't repair it myself though, i took it to the mechanic. Charged my 380 bucks!
Old Dec 1, 2007 | 09:18 PM
Hawkze_2.3's Avatar
Default Re: Prelude won't stay started (blackh23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackh23 &raquo;</TD></TR><TR><TD CLASS="quote"> Charged my 380 bucks! </TD></TR></TABLE>
OUCH! Gotta learn somehow.
Old Dec 2, 2007 | 06:31 AM
shanehate's Avatar
I had a 93 prelude that was doing the same exact thing and it was the ignition switch harness. and I got another one at a junkyard for 10 dollars.
Old Dec 4, 2007 | 05:30 PM
Bernod's Avatar
$380 WOW! It was a pain in the butt I got it done. The kicker is I paid $300 to get the radiator changed for a new one! What was I thinking? LOL
Old Dec 5, 2007 | 05:01 AM
92hondalude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bernod &raquo;</TD></TR><TR><TD CLASS="quote">Update the car is still running fine. New mystery has anyone had the mysterious clutch reservoir leakage? I put fluid in the clutch reservoir at least once a week.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Search the clutch line for leaks...it's probably coming from the clutch damper mounted to the passenger side frame rail.</TD></TR></TABLE>
yes try the damper, Or check the master under the dash for leaks
I just put my steelbraided line in. No more clutch damper
Old Dec 5, 2007 | 05:53 AM
night's Avatar
Default Re: (92hondalude)
the slave cylinder
tylerhonda_prelude
Mar 5, 2009 01:16 PM
dc4teg95
Dec 28, 2007 01:53 PM
jimjonez
Dec 13, 2006 02:52 AM
G0crxG0
May 9, 2006 05:29 PM
wtfitzsoda
Jan 18, 2005 03:43 AM
