electrical problem
Old Nov 16, 2007 | 11:18 PM
obuhmyuh's Avatar
Default electrical problem
maybe someone has some insight that i may have overlooked. so i took my ac fan out and cut the wires stupidly not thinking that some were hooked up to my radiator fan ( i had it gerry rigged because my fan would not turn on). but i finally got my fan to work but it stays on even when my car is off so i have to disconnect my negative batt terminal. one of my buddies suggested cutting the green and black wires that go into the thermostat (?) and connecting them to eachother so that my fan is always on when my car is, but nothing changed... im thinking maybe my radiator fan relay but idk...
Old Nov 17, 2007 | 08:17 PM
obuhmyuh's Avatar
Default Re: electrical problem (d[sick]sTeena)
helppp
Old Nov 17, 2007 | 08:48 PM
BUDtoker's Avatar
so why dont you just run your self a switch to turn your fan on !!!!!!! just make a stick that says turn on fan to put on your gauges so you dont forget to flip the switch when you star driving!!!!!!!!!!!!!!!!!!simple and effective but just dont forget to turn it on or you have problems
Old Nov 17, 2007 | 08:51 PM
BUDtoker's Avatar
Default Re: electrical problem (BUDtoker)
oh put the switch somewhere in your dash board or center console or whatever you find to be convinent switch will be under 10 bucks
kirkland08
Mar 5, 2011 01:15 PM
xTomei
10
Jun 7, 2010 06:02 PM
must32
Aug 22, 2008 03:28 PM
ev0luti0n
Jul 7, 2005 10:36 AM
