92 Accord EX, Transmission D4 light
I have a 92 Accord EX with a problem.
The car seems to be stuck in 3rd gear when I start off from a standstill. I can manually select all forward gears, however it appears that I only have two forward gears working (2nd and 3rd). Neutral, Reverse and Park all work fine.
At first the D4 light started blinking. Now it stays on regardless of which gear I select. Jumping the blue (2-wire) connector does not result in the D4 light blinking (indicating any codes).
I have read where these models have a history of burned resistors and leaking capacitors in the TCM. I haven’t pulled the TCM to see yet.
Do the symptoms I describe indicate a bad TCM?
Hondafreak2006
Sep 17, 2006 07:33 PM
