90 honda Accord LX, need help with brake upgrade
well, i want to upgrade my brake calipers from the accord oem brake calipers. i read on someone's thread that the Acura Legend brake calipers directly bolts on and the caliper uses dual pistons. need help clearing up this. i am also converting my rear drum brake set for a rear disc set, what do i need and what needs to be modified. thanks everyone.
Modified by SCoutZ at 10:44 PM 11/16/2007
i am planning on doing the same thing with my accord,already have all for the rear disc.conversion,just waiting till i have time but hope this helps you out
http://www.accordinglydone.com...=2056
what REAR disc did you convert to? Accord 5th gen? and what Front Brake caliper set up did you use? what year legend? V6 rotors as in 98+ V6 accord ex? this will help me so much. thanks.
from what i read out there,you could use any 5 gen.accord,i am going to used the rear disc that came from a 95 accord ex-that is for the drum 2 disc conversion it is all just bolt off and bolt on.if you have an accord that your going to use that rear disc from all you need to do is take everything from the knuckle out,don't forget the parking break and the soft-lines,go to your accord take everything out from the knuckle out and replace with the rear disc.as for my front i am going to use the legend and v6 rotors
humm, how much did it cost you for the Honda Accord EX rear disc units, is your abs or non abs? my accord is non abs. and what year is the ,legend calipers and when you mean v6, do you mean the legend v6 or the accord v6?
the accord ex rear disc setup cost me nothing,i saw one at a person's yard,stopped by and ask him about getting the rear setup he also has a 95 accord lx so like we help each other with our cars he gave it to me FREE,if i had gone there much sooner i would have gotten the engine that was in it VTEC,but someone beat me to it.as for my front calipers-it would be on a 94-95 Legend GS Sedan-rotors would be from a 95-97 accord v6/wagon.my accord does not have abs.the accord ex does but all you need to do is plug it up.check out below..hope this helps!
https://www.accordinglydone.co...=8300
Modified by honda671 at 2:32 AM 11/20/2007
ColeCooper90
Feb 27, 2019 01:35 AM
