6 3/4" in the rear of an 2 door teg?
Old Jun 24, 2002 | 02:25 PM
Rob :190:'s Avatar
Default 6 3/4" in the rear of an 2 door teg?
is it possible with cutting/dremeling, etc? or hell, maybe even fitting a free air 8"?
[Modified by Rob, 6:25 PM 6/24/2002]
Old Jun 25, 2002 | 02:33 AM
3RROR404's Avatar
Default Re: 6 3/4" in the rear of an 2 door teg? ( Rob)
Depth is not really a problem... I wish I'd measured when they were out. But tweeter hieght is an issue. 6.5ish will fit, just make sure that the tweeter is even with or lower than the outer cone lining. Infinity Kappa's will NOT let your stock grills go back on.
Old Jun 25, 2002 | 10:17 AM
Rob :190:'s Avatar
Default Re: 6 3/4" in the rear of an 2 door teg? (3RROR404)
is the tweeter height the only issue? if i go bigger than stock, i'll do seperates, so tweeter height wont really matter...
Old Jun 25, 2002 | 01:00 PM
3RROR404's Avatar
If you're gonna do separates, dont waste em on your rear fill, plz. Stick em up front where it counts. Are you looking for more bass, or a stronger rear fill? I think the Boston FX series uses a farily low profile tweeter placement.
Old Jun 25, 2002 | 05:15 PM
Rob :190:'s Avatar
not really for rear fill. ideally i'd like to fit a couple of free air 8s back there. I'm ditching the subs in the trunk, just looking for decent SQ now. seperates are definately going up front BTW
[Modified by Rob, 9:15 PM 6/25/2002]
Old Jun 26, 2002 | 12:02 AM
3RROR404's Avatar
The only problem I foresee would be the actual mounting of the 8's. Maybe a true 6.5 midbass or beefy coax and a foam baffle behind, unless you want to completely disassemble the entire rear interior of the car. You'd be surprised what a set of foam baffles will do for the bass repsonse on a 6" woofer. The old sound or speed dilemma. If all else fails, bazooka or infinity basslink; lighter than MDF, very efficient.
crexer
Apr 23, 2006 03:42 AM
K i l l a B e e.
Apr 9, 2006 03:51 PM
DI9ITAL
Feb 8, 2004 06:27 PM
Frost94GSR
Audio / Security / Video
Feb 25, 2002 10:25 PM
