question about AN- fitting
Old Nov 16, 2007 | 05:30 PM
IntegraType-R's Avatar
Default question about AN- fitting
Fuel rail is a golden eagle pro series fuel rail, i have a gauge i wanna put on the other side, is there a fitting that will allow me to screw my gauge in, the opening hole is too big, i think its a 3/8's opening...is there some type of adapter.
Old Nov 17, 2007 | 09:32 AM
d16dcoe45's Avatar
Default Re: question about AN- fitting (IntegraType-R)
There are many ways to adapt it, most will require at least 2 fittings, but I think you can find something that will work, try this:
http://store.summitracing.com/...w=sku
Then you just need to get a -6an cap from Earls or Aeroquip.
The above is assuming the female in the fuel rail is 3/8" NPT.
Old Nov 17, 2007 | 11:37 AM
IN VTEC's Avatar
That fuel rail should have a 1/8" NPT port on the top for a wet nitrous fuel supply or for a fuel pressure gauge or sensor.
Use a 1/8" NPT male to 1/8" NPT female 90 degree elbow. See mcmaster.com for the fitting.
Old Nov 17, 2007 | 12:51 PM
Default Re: question about AN- fitting (IN VTEC)
check that now thx.
Old Nov 17, 2007 | 01:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">That fuel rail should have a 1/8" NPT port on the top for a wet nitrous fuel supply or for a fuel pressure gauge or sensor.
Use a 1/8" NPT male to 1/8" NPT female 90 degree elbow. See mcmaster.com for the fitting.</TD></TR></TABLE>
sir you = Thxyou
it worked perfectly i didn't even notice that opening..thx you very much it fit and works perfectly.
Superman137
Apr 7, 2008 07:53 AM
skUnK2jdm
Jan 30, 2007 12:00 PM
EVIL_AWD
Mar 27, 2003 08:55 PM
niedejb
Aug 5, 2002 10:31 PM
