Its soooo cooolldd. Heater issues inside.
Old Nov 16, 2007 | 11:09 AM
fatboi07's Avatar
Default Its soooo cooolldd. Heater issues inside.
96 civic dx. Heat works but only stays on face vents but will switch to floor but not defrost for the window where I need it the most. What could be the problem? Thanks ht.
Old Nov 16, 2007 | 11:27 AM
fmrprojects's Avatar
Default Re: Its soooo cooolldd. Heater issues inside. (fatboi07)
sometimes heat doesn't always defrost the best. use your a/c to defrost the front window, its much faster.
Old Nov 16, 2007 | 11:35 AM
BUDtoker's Avatar
Default Re: Its soooo cooolldd. Heater issues inside. (fmrprojects)
could be a broke flapper in the vents! take your ac/heater control cover off and look and see if the lever moves listen for a flap noise when you move it to defrost position if it dont work you gotta take the dash apart and see what is broken?
Old Nov 17, 2007 | 12:30 PM
fatboi07's Avatar
Thanks guys will do.
bitur6
Honda Civic (2001 - 2005)
Jul 15, 2018 11:45 AM
dpkelly
Honda Civic (2006 - 2015)
Dec 10, 2013 09:34 PM
awwsnap
Aug 14, 2005 06:41 PM
DaveSi677
10
Jul 6, 2005 11:57 AM
