***pistons***
Old Nov 16, 2007 | 09:41 AM
jrs95civic's Avatar
Default ***pistons***
Wat kind of pistons are good to increase speed/power on my d16z6...
Old Nov 16, 2007 | 09:43 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: ***pistons*** (jrs95civic)
No type alone will give you a good increase in power.
Old Nov 16, 2007 | 09:46 AM
jrs95civic's Avatar
wat about cams???
Old Nov 16, 2007 | 09:51 AM
.:Swig:.'s Avatar
Default Re: (jrs95civic)
stock or aftermarket? y8 pistons will raise your compression if thats what you want
Old Nov 16, 2007 | 09:57 AM
crazyguy's Avatar
spend money and alot of labor on cams and pistons and other internal engine upgrage for a n/a d16z6 wont make much hp gain.
Old Nov 16, 2007 | 10:08 AM
Lscivic1999's Avatar
Default Re: ***pistons*** (crazyguy)
turbo SOHC..
Old Nov 16, 2007 | 10:25 AM
jrs95civic's Avatar
turbo is my dream.. cant affort it tho...well thanx for the info... peace...
Old Nov 16, 2007 | 11:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: ***pistons*** (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">No type alone will give you a good increase in power.</TD></TR></TABLE>
Incorrect.
There are numerous OE honda pistons that will increase compression, thus increasing whp and torque.
I personally built my D16A6 non-VTEC 1.6L SOHC engine with higher domed P29 pistons and the engine rips much better than a regular old D16A6.
..but in the end you will either spend a lot of money on labor, not a lot in parts and still not be crazy fast, or if you are capable of doing the build yourself then it can be done pretty cost effectively and it'd be worth it IMO.
Old Nov 16, 2007 | 11:45 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: ***pistons*** (B18C5-EH2)
Really? How much more with just pistons? Can't be a lot.
Old Nov 16, 2007 | 01:10 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Really? How much more with just pistons? Can't be a lot.</TD></TR></TABLE>
If you don't think going from 9.2:1CR (stock D16A6 and D16Z6 CR) up over 11:1CR (hell some pistons get retarded 13:1CR if you really want to go nuts) won't yield better than "can't be a lot more" horsepower gains then I don't know what else to tell you.
Not to mention the obvious "repair" that would take place if one were to hone and/or bore cylinders, replace bearings, gaskets, etc. I mean rebuilding a miled up, crusty-*** engine with stock parts alone will yield some gains. Toss in some added compression and the gains are better than you might think.
We are arguing just to argue at this point though. Increasing CR will raise horsepower and torque - you can debate by how much all you like, but you originally said:
...and I respectfully disagree from first-hand experience with me rebuilding my own SOHC and having it rip after I was done.
Now is it worth it to a regular guy looking for crazy hp?
Probably not.
Most people have this idea of rebuilding a SOHC to go and roast GS-R swaps, and honestly that isn't usually the case. I happen to work at a shop, so I could do all my own work (except some machine shop stuff like pressing new pistons and wrist pins onto my old rods) so for me it was actually fun, relatively cheap (actually much cheaper than a swap in my EF because of mount kits, linkages, etc.) and I wasn't expecting world domination out of it.
What I did get was a non-VTEC SOHC engine that hangs with, and sometimes runs quicker than some B16A swaps and every LS swap I've ran across thus far.
Also people seem to think that pistons are an easy thing to do. What they don't realize is that you're completely tearing down and rebuilding the entire engine, which requires a degree of skill, patience, and a certain extra level of money well beyond just buying pistons themselves.
vtecb18frank
Oct 30, 2007 06:28 AM
lunch_box_4_life
Oct 17, 2007 09:27 AM
yellowjdmcrx
Sep 1, 2005 06:32 PM
cascaritas
14
Mar 26, 2004 07:46 PM
TurboHatch01
Feb 16, 2004 05:05 PM
