The BEST $16 DIY CRX front lip. (From Intgera)
Old Nov 16, 2007 | 08:52 AM
brg2nr's Avatar
Default The BEST $16 DIY CRX front lip. (From Intgera)
My pictoral DIY. (I searched but did not find any info on front lip DIY's for CRX. Forgive me if this is covered)
Lip from an 1989 Acura Integra (4door in this case), front CRX bumper removed from car.
Nuts, bolts and washers from Home Depot. All the bolt holes on the lip will match up with the ones on the bumpers.
I know this is true of all 90-91 Civic/CRX's. Someone LMK if 88-89 line up.
On the underside of the lip mark and cut out as pictured.
Heat up the plastic with a blowdryer or heat gun if you want to make it a little easier to slice with the Olfa knife.
This is to allow the sides of the lip to form to the CRX bumper which has more of an angle on the sides.
After bolting the lip on you will have to trim the sides off, depending on which car you are doing it will be a different length so it's best to leave it untill last.
The only hole that you will have to drill is pictured with the bolt in it in the second picture.
You may need another set of hands to help you press the lip against the bumper while you drill and bolt this hole.
A closeup of the bolts and holes...
The bolts and washers x 12 (a couple extra never hurts)
A couple pics of the bumper before install on the car.
Forgive the bad rattle can job.
Proof that it only cost me $16 Cdn!
I am really impressed on how it looks on my 1991 CRX.
The Integra lip is the same shape as the stock shape of the rear on the CRX...
they look good together! Now I just have to go get a paint job on the front bumper!
Thanks for looking!
~Brett
Modified by brg2nr at 11:58 AM 11/16/2007
Old Nov 16, 2007 | 09:13 AM
evertp1's Avatar
WORD
Old Nov 16, 2007 | 09:16 AM
jacoop86's Avatar
Default Re: The BEST $16 DIY CRX front lip. (brg2nr)
and i'll be junkyarding this weekend....
Old Nov 16, 2007 | 09:50 AM
turkishEF's Avatar
Default Re: The BEST $16 DIY CRX front lip. (jacoop86)
Good job!
Old Nov 16, 2007 | 10:28 AM
sloweredcivic's Avatar
some times the cheaper things are the nicer things good work
Old Nov 16, 2007 | 10:48 AM
gator88's Avatar
Default Re: (sloweredcivic)
handsdown the best DIY lip ive ever seen. Looks clean yet looks "modified" Looks purty ****** good, im doing it!
Old Nov 16, 2007 | 11:06 AM
CBURKE's Avatar
I really like that, screw buying the CRX si lip!!!
Now I just have t find one of these bastards!!!
Old Nov 16, 2007 | 11:09 AM
Maxcapacity's Avatar
Default Re: (gator88)
They do look snazzy, I been rockin mine on my 89 for over a yer now!
Old Nov 16, 2007 | 11:50 AM
ludesrv's Avatar
Default Re: (T- rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T- rex &raquo;</TD></TR><TR><TD CLASS="quote">They do look snazzy, I been rockin mine on my 89 for over a yer now! </TD></TR></TABLE>
So I guess this is the confirmation you wanted?
Old Nov 16, 2007 | 12:14 PM
brg2nr's Avatar
Default Re: (ludesrv)
Ya I guess that would confirm that it fits on 88-89's as well!
T-rex... do all the bolt holes line up perfectly like the 1991 did?
Old Nov 16, 2007 | 12:45 PM
dmpd_ef's Avatar
Default Re: (brg2nr)
haha nice man. whats funny is a just did this a few hours ago to my da before looking on this thread. i found the only AV integra in the whole junkyard that still had the lip. yours looks cleaner tho
Old Nov 16, 2007 | 12:53 PM
JG90CRX-Si's Avatar
Default Re: (dmpd_ef)
Sweet, good to know if I ever need one.
JG
Old Nov 16, 2007 | 01:26 PM
x4thGenCafe's Avatar
OF THE KINGS
Default Re: (JG90CRX-Si)
loooks ****** aggressive.
me likey
Old Nov 16, 2007 | 01:28 PM
OF THE KINGS
Default Re: (x4thGenCafe)
make one for the rear bumper yet ????
if soo lemmme seeee that !
haha
Old Nov 16, 2007 | 02:07 PM
fireant's Avatar
Looks nice... alot like the CRX lip, but sticks forward a bit more right?
Old Nov 16, 2007 | 02:34 PM
vacantskies88's Avatar
Default Re: (fireant)
Nice job Looks good
Old Nov 16, 2007 | 02:36 PM
Braco11's Avatar
clean!
Old Nov 17, 2007 | 07:42 AM
thevtecnician's Avatar
Default Re: (evertp1)
Not bragging or anything but I've been rocking this for about 3 years now. Thanks for giving away the secret
Yeah they fit on 88-89's too you just have to cut more off the end. And my local pick n pull sells em for $6
Old Nov 17, 2007 | 10:19 AM
CBURKE's Avatar
You can only get them off the 4 door Teg?
Old Nov 17, 2007 | 10:42 AM
Andrew Marquis's Avatar
I did this to my rex a long time ago. Never looked back. it was the best $10 lip I know of
-Andrew
Old Nov 18, 2007 | 04:13 PM
neozero999's Avatar
Default Re: (Andrew Marquis)
just wanted to show what i just put on, i took a 87 toyota cressida lip and fit it on my rex, although none of the holes match up except at the ends and in the middle, i thought it look good heres some pics, i had to trim the edges and the middle piece, and used zip ties to hold the lip up securely.*hehe* we shall see how she holds up!
&lt;br/&gt;
&lt;br/&gt;
&lt;br/&gt;
&lt;br/&gt;
&lt;br/&gt;
Old Nov 18, 2007 | 04:53 PM
Default Re: (neozero999)
Clean I like the cressida one more
Old Nov 18, 2007 | 06:55 PM
JOEY F.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brg2nr &raquo;</TD></TR><TR><TD CLASS="quote"> Someone LMK if 88-89 line up.
Worked on my 88-89 sedan bumper
Old Nov 18, 2007 | 11:53 PM
wakaranai's Avatar
Man, i wish the pick n pull peeps were as dumb/cool as the ones in BC. Here they charge you $22 for a "front bumper lip."
Diggin the Cressy lip. When I used to have my AE86 , I thought about putting one of those on it.
Old Nov 19, 2007 | 08:51 AM
K20ACRX's Avatar
Good find!!
