95 civic air bags removed need srs light off
Old Nov 16, 2007 | 07:43 AM
95 honda8's Avatar
Default 95 civic air bags removed need srs light off
I have a 95 civic ex 2 coupe and I am removing my air bags (new steering wheel on driver side and removing pass side) my ? is how can I get my light on my dast off is there a wire I can cut??? I need this to pass inpections. thanks and if someone could take pics so I can see what u are talking about that would be great and thanks agin HT,
Old Nov 16, 2007 | 07:47 AM
crazyguy's Avatar
Default Re: 95 civic air bags removed need srs light off (95 honda8)
i removed my oem air bag equipped steering and i pull the whole culster off trying to figure out which bulb to take out or which wire to cut.but i cant find any cause the srs bulb is built into the cluster.so i had to take off the cluster plastic cover and carefully lift the gauge face and break that bulb. but that is just me. it should be other easy way
Old Nov 16, 2007 | 07:51 AM
95 honda8's Avatar
Default Re: 95 civic air bags removed need srs light off (crazyguy)
thanks man I have heard people befor talking about a yeelow wire that will turn it off, dose ayone know about this an were is the wire
Old Nov 16, 2007 | 08:02 AM
platinumx6's Avatar
Haynes manual has a lot of wireing diagrams maybe its in there? worth a shot.
Old Nov 16, 2007 | 08:05 AM
95 honda8's Avatar
Default Re: 95 civic air bags removed need srs light off (platinumx6)
thanks got one I will look in the mean time any more help would be great
Old Nov 16, 2007 | 09:15 AM
95 honda8's Avatar
looked in Haynes manual I did not see it any help
Old Nov 16, 2007 | 03:27 PM
jdmef9gsr's Avatar
cant u just unplug it from the cluster it the yellow plug
Old Nov 16, 2007 | 03:44 PM
Crasian's Avatar
^ thats all i did
Old Nov 16, 2007 | 03:47 PM
BlueIntegraBoy's Avatar
Default Re: 95 civic air bags removed need srs light off (jdmef9gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmef9gsr &raquo;</TD></TR><TR><TD CLASS="quote">cant u just unplug it from the cluster it the yellow plug</TD></TR></TABLE>
Yes, this is the easiest way.
95 honda8's Avatar
Default Re: (Crasian)
so it not a yellow wire its a yellow plug??
Old Nov 16, 2007 | 03:49 PM
Default Re: (95 honda8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 honda8 &raquo;</TD></TR><TR><TD CLASS="quote">so it not a yellow wire its a yellow plug?? </TD></TR></TABLE>
Well, the SRS yellow plug has three wires: black, blue, and yellow. Just remove the whole plug from the cluster.
Old Nov 16, 2007 | 03:50 PM
95 honda8's Avatar
Default Re: (BlueIntegraBoy)
no one has pics of this do they?
Old Nov 16, 2007 | 03:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 honda8 &raquo;</TD></TR><TR><TD CLASS="quote">no one has pics of this do they?</TD></TR></TABLE>
You don't need pics. Just remove the bezel, 3 screws (2 up top, 1 behind the hazard switch). 4 screws holding in the cluster. Remove yellow SRS plug. Put back everything.
Yellow plug, right next to the green one.
Old Nov 16, 2007 | 03:59 PM
95 honda8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
thanks man you have been a big help
Old Nov 16, 2007 | 06:25 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 honda8 &raquo;</TD></TR><TR><TD CLASS="quote"> I need this to pass inspections. </TD></TR></TABLE>
I don't know were you live but in most inspections in the U.S. if the car had air bags they need to be there to get the car to passs.
Here is a link to put them back in and to shut off the srs light. It works.
http://www.geocities.com/myint...00714
Old Nov 16, 2007 | 06:51 PM
95 honda8's Avatar
Default Re: 95 civic air bags removed need srs light off (wrx-killer-Sti-eater)
thanks
just_bn_me83
May 15, 2012 05:34 PM
SoleFresh N Clean
Aug 10, 2010 11:18 AM
Jimmy604
Jan 13, 2008 02:32 PM
4DRmafia
16
Oct 29, 2006 08:12 AM
