Tips in removing pedal assembly needed
Old Jun 24, 2002 | 01:30 PM
L4NDO's Avatar
Default Tips in removing pedal assembly needed
Does anyone here have tips on removing the pedal assembly on your car? I have some weak pedal covers on my car that I need to remove. But after I remove them, there are going to be holes where screws have been drilled through. I decided that I'm just going to replace the entire pedal assembly. Can anyone provide some tips?
Old Jun 24, 2002 | 01:34 PM
SoloSol's Avatar
Default Re: Tips in removing pedal assembly needed (L4NDO)
Okay if some holes on the pedals are going to drive you so nuts that you must replace them. Start By removing the steering shaft and wheel as one assembly. Unplug the elect. connectors and there are cables for the accelarator and 10-15 bolts you will need to remove. Dude it is a pain in the ***.
Old Jun 24, 2002 | 06:25 PM
L4NDO's Avatar
Default Re: Tips in removing pedal assembly needed (SoloSol)
ttt
Old Jun 24, 2002 | 07:20 PM
L4NDO's Avatar
Default Re: Tips in removing pedal assembly needed (DragonCTR69)
If I brought it to a shop.. Do you know what the estimate could be on the labor charge?
Old Jun 25, 2002 | 09:37 AM
L4NDO's Avatar
ttt
hashback*
Feb 12, 2007 07:27 PM
johnzm
Mar 13, 2003 11:50 PM
Dr Pooface
Sep 15, 2002 09:38 PM
