First time at the track gsr integra. HOW DID I DO?
Old Nov 16, 2007 | 01:50 AM
Ricer no 7's Avatar
Default First time at the track gsr integra. HOW DID I DO?
hey i just went to the track this wedsday pretty good expierience how you think i did
gsr integra
dc 4-1 headers dented to **** i need to put my stock ones back on the two bottom primaries are half closed
2 1/2 inch exhaust
knock off twin loop muffler
nex coilovers
and no spare tire
old street tires
best time was
15.126 et
87.513 MPH
2.327 60ft
other times were relatively close ranging from 15.126 to 15.318
except once the track became shitty to much tire on the track i couldn't launch anymore. They didn't prep the track and there was alot of rubber an tire on it eh.
well tell me what you think i was pretty excitied with the times. Need some new headers though my car is too low for mine.
Modified by Ricer no 7 at 8:42 PM 11/17/2007
Old Nov 16, 2007 | 11:54 AM
h22crxpwr's Avatar
Default Re: First time at the track gsr integra. HOW DID I DO? (Ricer no 7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricer no 7 &raquo;</TD></TR><TR><TD CLASS="quote">hey i just went to the track this wedsday pretty good expierience how you think i did
gsr integra
2 1/2 inch exhaust
twin loop muffler
nex coilovers
and no spare tire
old street tires
best time was
15.126 et
87.513 MPH
2.327 60ft
just work on your 60' times. try not to just full on lay into the pedal as you are on street tires. practice and it will only get better.. or go buy some slicks and full on launch it and hit 14's easy... once you go slicks you will never want to run a street tire again!
Old Nov 16, 2007 | 12:37 PM
allmotaeg6's Avatar
Default Re: First time at the track gsr integra. HOW DID I DO? (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">
once you go slicks you will never want to run a street tire again!</TD></TR></TABLE>
thats the truth right there...but as said work on your 60ft and you will see improvements
Old Nov 17, 2007 | 07:38 PM
Ricer no 7's Avatar
What 60ft time should I aim for with normal street tires??
An what tire pressure should i run in them??
just wondering because I don't have money for slicks.
I need new motor mounts and a header first. Cause i can use those i on the street if i buy slicks i can only use them at the track.
An help would be much needed techniques on launching etc
Old Nov 17, 2007 | 07:41 PM
Ricer no 7's Avatar
That is around the time i should have run right??
I believe a bone stock gsr runs around a 15.4 or 15.3
What should i be hitting with this set up ??
An what is your 60ft times on street tires anyone??
Old Nov 18, 2007 | 02:35 PM
Ricer no 7's Avatar
thanx for the posts but anyone else have any info
what i should hit with my set up??
is this time okay is it slower? what 60ft i should hit on street tires??
anyone??
Old Nov 18, 2007 | 02:50 PM
blueDA9's Avatar
those times are about right given the 60 ft times and all, not meaning to thread jack here, but, last time i went out to the track i had a 2.2 60 ft, in a 90 rs integra, stage 2 clutch, lightweight flywheel and a 4-2-1 header, with a sp2 knock off, but i only managed a 16.1, is it because the original owner put huge 17's on it or what?
Old Nov 18, 2007 | 02:59 PM
Ricer no 7's Avatar
Default Re: First time at the track gsr integra. HOW DID I DO? (blueDA9)
Thats pretty good for an rs. An ya the 17 prolly don't help much.
The 60ft time was on street tires right? Thats a good 60ft
Damn i need to hit 2.2 on my street tires. What psi should i run in my street tires at the strip??
good job on the 2.2 60ft
Old Nov 18, 2007 | 03:05 PM
blueDA9's Avatar
i take about 10 psi out every run till I start to slow down, once that happens i put a lil more in there. I run 35 psi when im DD, i go to 25 at the strip, if i spin to much I take some more out, my psi for the best traction with my tires is around 20, so just experiment next time you go.
Modified by blueDA9 at 6:45 PM 11/18/2007
Old Nov 18, 2007 | 03:06 PM
Team 400M_Dr. Pepper's Avatar
Man. You guys make me miss my old baby..
95-Door teggy RS
Cams, Carbs, Head work.. It knocked on 13's door like it was nobodies buisness.. Lol..
Nice job ricer.. Keep getting your practice in. It does wonders!! ~X
Old Nov 18, 2007 | 09:07 PM
FastEg6's Avatar
Pretty good, work on that 60ft and mess around with your tire pressure each round and see what will happen. I'm sure you'll get into the 14sec rang easily.
Old Nov 29, 2007 | 12:44 AM
gsr_t12i's Avatar
What was the rpm that u took off at..? im just curious. i had a Ls a few yr's ago and ran a 15.8 with ihe.. i now got a gsr.. just wondering what i can do.
Old Nov 30, 2007 | 12:39 PM
blacK_Dc4's Avatar
which track did u go to ? .. personally , i think that the 87 mph is a little low for a healthy gsr .. i hit a 14.9 with my gsr when it had i/h/e with a 93 mph and a 2.2 60ft at sears point, Sonoma about a year ago
Old Dec 16, 2007 | 03:33 AM
Ricer no 7's Avatar
Default Re: First time at the track gsr integra. HOW DID I DO? (blacK_Dc4)
yah my bottom two primaries on my dc header are really dented i think its affecting my top end flow. The two primaries on the 4 -1 the two lower ones are about half size my car is too low. hit a pot hole.
Sacramento race way
weds night drags the track is un preped since it free run.
yah also i don't have an intake just stock one with stock filter
So i kind of have just exhuast and hi flow cat.
Buyin new headers soon
Old Dec 16, 2007 | 03:36 AM
Ricer no 7's Avatar
Default Re: (gsr_t12i)
you should run around 15.4 or 15.3 on a stock gsr.
And i launched around 2400 and i don't drop it. I have shitty street tires damn i need money to buy things ehh.
But with some nice tires you should launch around 2600 on good track conditions.
later in the day launched around 2000 since the track got shitty.
I donno thou my lauches arent that great.
anyone have any info on launching
gsr's with out lsds and street tires not drag radials or slicks
Old Dec 16, 2007 | 04:41 AM
huertascoupe's Avatar
Default Re: (Ricer no 7)
how high are you reving to ?
Old Dec 16, 2007 | 10:24 AM
MindLess311's Avatar
i used to run my street tires 16-20 psi and could get 2.0 60s but for your first time out not to bad the best thing u can do is practices o and get slicks lol
Old Dec 16, 2007 | 06:29 PM
Ricer no 7's Avatar
Default Re: (huertascoupe)
Stock rev limit
Don't need to rev higher my car basically stock
Old Dec 16, 2007 | 06:31 PM
Ricer no 7's Avatar
Default Re: (MindLess311)
yah i should have tried dropping my psi alot more
i think i was running around 25 to 27 psi.
I didnt think you should drop it that much on street tires
Thats a real good time for street tires what kind where they? were they drag radials
cuz thats real low for street tires?
Props thou for a good 60ft
Old Dec 16, 2007 | 06:33 PM
Ricer no 7's Avatar
anyone have any have any
cheap used tri y headers for sale
don't have enough to buy for 350 new hehe
o
and motor mounts or just inserts mine are shot
Old Dec 16, 2007 | 06:39 PM
i was on falken ziex super shitty tires i would get 1.8s on bfg 225 drs and now getting 1.6s on slicks hehe hopefully 1.5s next year
Old Dec 17, 2007 | 01:34 PM
cfwthb_94's Avatar
i have a 95 gsr and when i first bought it I ran a 15.1 @ 91mph w/ 2.3 60' on stock tires 23.9" 205/55/15. car was bone stock. that was in nov. of last year holding top of third gear across the finish line. During the summer I was running 15.6-7 and occationally 15.3 in the heat, with 22" 205/50/14 bf g drag slicks and 2.2-2.3 60' at 89mph. I would swap back and forwarth between them and the street tires. With the 22" i would be at 89mph and with the 23.9" i ran 91-92mph and it ran the same no matter what tire I had on it.
I put on a blox intake manifold and got it tuned with the stock exhaust, and it made 143hp, was at 140hp so not much of an improvement, during the summer.
Took it back to the track and ran the same times.
I put on 2.5" exhaust, from a local muffler shop with a magnaflow muffler, stock cat, drag radials. But this time I ran it in September once and it clicked off a 15.0.
Went to the track the sunday after thanksgiving, nothing different, and ran a 14.7 at 2.1 60' three times, a bunch of 14.8. total of 20 runs that day, plus what my gf did. all around 92-93mph with the 22" drag radials. I finally figured out how to heat up the slicks real good.
Just some refrences for you to go by.
Old Dec 17, 2007 | 01:56 PM
high_revs's Avatar
not half bad....just work on those 60's and you'll get into the 14's
Old Dec 17, 2007 | 02:17 PM
sittin on chrome's Avatar
Default Re: (h2b_eg8)
not bad at all
Old Dec 18, 2007 | 07:15 PM
Ricer no 7's Avatar
Default Re: (cfwthb_94)
good times
jw
what is a normal 60ft time for Stock 205 tires (i have dunlop direzzas that are bald) ?? Yah i have 205s i forgot the other numbers 205/??/?? prob what stock readings anyways i don't want to go out side and look at my tires.
BUt on stock you dropped your psi to 20psi?? does that affect your top end??
O so you ride out 3rd gear instead of shifting to 4th?? Just wondering because i shift into fourth right at the end of the drag?? Can i ride it out with the stock rev limit?
thanks for the replies
