anyone know a diy for fuel pressure gauge?
There is nothing to it, relieve fuel pressure by opening gas cap then remove the top 17mm bolt on top of the fuel filter and remove it there should be 2 copper crush washers remove those as the gauge should have came with new ones put a washer on top of the banjo line and one on bottom and just tighten it up. The gauge should screw on top of the new bolt you used you can use some teflon tape if you want. Make sure to tighten everything down and tighten your gas cap.
sorry if i was misleading im not asking how to install, i was wondering if anyone has made one, like from the gauge off and air compressor or so?
haha i just thought cuz i heard some friends talking about it, and is there any questions as to whether the pressure gauge off an air compressor is any different from a fuel pressure, cuz i think they would be the same but any opinions?
the guages are way diff just pick up a fuel injection compatible fuel pressure guage off ebay or something ...round 20-30 bucks maybe less
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jax75z28 »</TD></TR><TR><TD CLASS="quote">the guages are way diff just pick up a fuel injection compatible fuel pressure guage off ebay or something ...round 20-30 bucks maybe less
Yeah man, just buy it, mine was like 30 bucks.
if you were to use an aftermarket fuel rail with a stock fuel pressure regulator, would you gain any horsepower from that?
