can anyone help me with this dizzy issue
Old Nov 15, 2007 | 05:27 PM
turbob18si's Avatar
Default can anyone help me with this dizzy issue
[/QUOTE]
the large white wire that is for ICM which side of the harness should I find it on? Im in the middle of a crisis please help the crx the motor came out of had the white wire coming from the driver side but the crx its going into doesnt have a white wire on that side all the other wires match up except that one, it came out of and hf converted to obd1 and Im trying to duplicate that going into an si. redoing someone elses conversion sucks
Old Nov 15, 2007 | 05:32 PM
bossman032's Avatar
Default Re: can anyone help me with this dizzy issue (turbob18si)
I am confused by reading what you wrote.
if only one wire is not matching then connect it together, because its obvious its that wire if all the other wires are matched.
Old Nov 15, 2007 | 05:36 PM
turbob18si's Avatar
Default Re: can anyone help me with this dizzy issue (bossman032)
Im gonna have to take pictures to clarify things I know what Im trying to say but Its not coming out right
Old Nov 15, 2007 | 06:57 PM
jlicrx's Avatar
sounds like you are trying to use the HF engine harness in the Si car - not going to work, unless you do this:
look at the 8-pin connector on the driver's side:
the Si wire colors are:
blue/yellow
yellow/black
red
brown
light blue
yellow
black/yellow
dark blue
the HF wire colors are:
blue/yellow
yellow/black
red
brown
light blue
yellow
yellow
white
the wires (except for one) are in different locations in the HF and Si connectors
the igniter wire (code 15) is the white wire in the HF harness connector at the driver's side - the igniter wire (white) in the Si harness is in the passenger side connector
the HF engine harness will also have a connector for the EGR valve with 3-wires, yellow, yellow/white and green/white - the 89-91 Si engine harness also has a connector for the fast idle control valve with 2-wires, dark blue and black/yellow
to make the HF engine harness work with the 89-91 Si chassis harness, first, repin the wires in the 8-pin driver's side HF harness connector so that they match color for color with the Si chassis connector - you will have 2 wires that don't match, one of the yellows (from EGR) and a white (igniter) on the HF connector and black/yellow and dark blue (both from fast idle control valve) on the Si connector - forget these as they won't be used - notice that the HF connector has 2 yellow wires - the yellow wire for injector #4 is the only one that is in the same location on both connectors and is the yellow that is used - next, go to the round 6-pin connector on the passenger side - on the HF harness, find the yellow/white wire from the EGR valve - it should be in the same location as the white igniter wire in the Si chassis harness - at the other end of the yellow/white wire at the EGR valve connector, cut this wire - at the distributor connector, find the white igniter wire - it is the thicker white wire (see diagram below) - cut the white wire - connect the yellow/white (from the 6-pin passenger side connector) that went to the EGR to the white igniter at the distributor connector - make sure that all other wires in both the 6-pin and 14-pin connectors on the passenger side match color for color at both sides of the connectors - on the OBD1 distributor, the yellow/green wire is the igniter wire and matches the thicker white igniter wire in the HF harness - NOTE: some aftermarket OBD1 distributors have the orange and white wires reversed
Old Nov 16, 2007 | 10:13 PM
turbob18si's Avatar
Default Re: can anyone help me with this dizzy issue (jlicrx)
dude thats exactly what I needed your a total lifesaver
Old Nov 30, 2007 | 04:58 PM
neozero999's Avatar
i dont mean to jack the post but i wanted to know if i should use the hf harness when doing a d16z6 swap, not re-using it but using together with the z6 harness....
Old Apr 2, 2013 | 09:09 AM
91ReXz6's Avatar
I have a 91 Crx si with a z6 swap and HF harness . I did all this told me to do ^ and still no spark! . Any help??
90crxdriver
Jul 6, 2008 11:59 AM
95_red_dc
Jan 10, 2007 08:22 AM
1 Fly SI
19
Nov 15, 2006 09:14 AM
REDBARON
Sep 22, 2006 06:51 PM
HybriDNA
Feb 12, 2003 05:44 PM
