Honda S2000 Honda S2000
Calling all Lowered s2000
Old Nov 15, 2007 | 04:48 PM
Truong09's Avatar
Default Calling all Lowered s2000
Hey guy and girls
I am trying to see how much cheaper it would be to do a group buy on T1R rear bumpsteer kits & drive shaft spacers.
Rear Bumpsteer kit retails @ 450.00
Driveshaft Spacers retails @ 120.00 - 180.00
Quoting AJR
"The T1R anti-bumpsteer kits replaces the the rear toe rod of the S2000. By replacing it, it solves two of the most common problem of the S2000 rear suspension: It reduces and nearly eliminates potentially dangerous bumpsteer in cars lowered up to 2.5-3 inches. It also allows independent adjustment of rear toe, camber and the rod leveling. The T1R anti-bumpsteer kit is made out of A6061 forged aluminum with high tension spherical bearing for quality assurance. Available for 00-07 S2000"
I am trying to find 10 or more guys and girls to do this group buy. I will check the cost and only after I would need a deposit of 100.00 non refundable dollars to assure no one backs out.
I am located in, Richmond BC
I have the prices, Hopfully I can get 10 or more guys intrested
IM for the prices.
Old Nov 15, 2007 | 05:54 PM
Truong09's Avatar
Prices are now all availbe through IM's
Old Nov 15, 2007 | 06:06 PM
toofast4u752's Avatar
how about the front bumpsteer kit? my car aligned just fine without the need for the rear kit... then again im only lowered about 1.5" but i am interested in the front to level my tierods...
Old Nov 15, 2007 | 06:52 PM
Truong09's Avatar
I think I can get a group buy for those too if you are intrested .. The rear bump steer kit really helps on those rainy days
Esp for me, Im running A048's in the winter .. Im poor
Old Nov 15, 2007 | 10:26 PM
i dont really see the need for the rear kit, unless your lowered enough to where the toe and camber doesnt have enough adjustability to set to decent specs...
i dont see what else these these can do... i was able to set my rear toe and camber just fine with the stock adjustment points....
on the front i know that the angle that which the tie-rod sits at will have a big affect on bumpsteer....
Old Nov 16, 2007 | 04:36 AM
papa5murf's Avatar
Default Re: Calling all Lowered s2000 (Truong09)
I would actually be interested in the driveshaft spacers.
On another note, do you happen to work for AJR?
Old Nov 16, 2007 | 01:30 PM
Truong09's Avatar
No I do not. Im not sure if anyone is on the ITR forums, But my brother was part of DOULIK industries.
Just AJR happened to be the only guys that carry it
sleepencivic
Apr 5, 2017 04:24 PM
cesshonda
Honda S2000
Feb 13, 2011 11:07 AM
bb6
Aug 25, 2005 02:22 PM
