what kind on engine??
Old Nov 15, 2007 | 03:10 PM
joey funk's Avatar
Default what kind on engine??
my friend has a 95 civic ex with a v-tec and i'm not sure what motor he has?
i'm thinking a b16 or b18?
Old Nov 15, 2007 | 03:15 PM
philosofy1's Avatar
Default Re: what kind on engine?? (joey funk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey funk &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a 95 civic ex with a v-tec and i'm not sure what motor he has?
i'm thinking a b16 or b18?</TD></TR></TABLE>
if it's a stock motor, it's a D16.
it wouldn't be a B16 or B18 unless previously swapped.
the engine code can be found on the block, in the front, to the left on the exhaust manifold, where the block meets the tranny.
actek23's Avatar
if its an ex... i'm sure he has a D16 SOHC vtec, no civic ex came with a B16 or B18
the B16 and B18 are DOHC.
Old Nov 15, 2007 | 03:33 PM
Bejita's Avatar
First off its VTEC. Second. Like the others said. The ex civics came with D16Z6 engines in them. They are single over head cam motors.
Old Nov 15, 2007 | 04:25 PM
hoo my gosh's Avatar
to the people responding with the answer, d16z6. how do you guys know that the car is stock? he obviously doesn't know what motor he has and clued in b16 or b18.
to the original poster, post up a picture of the engine bay and we can go from there. or like philosophy said, check the stamp on the block.
Old Nov 15, 2007 | 09:34 PM
ejoner's Avatar
Default Re: (hoo my gosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoo my gosh &raquo;</TD></TR><TR><TD CLASS="quote">to the people responding with the answer, d16z6. how do you guys know that the car is stock? he obviously doesn't know what motor he has and clued in b16 or b18.
to the original poster, post up a picture of the engine bay and we can go from there. or like philosophy said, check the stamp on the block.</TD></TR></TABLE>
Reading pwns you, retard. Whats the point in you giving your opinion on this if the question was already answered? And if you actually read it someone already told him if the car is swapped then it will have a bseries motor.
Old Nov 15, 2007 | 09:42 PM
Syndacate's Avatar
No offense man, but judging by the lack of knowledge shown by the OP, I doubt he actually knows the difference between any Honda motors, 'cept that some say VTEC on them and some don't. "V-Tec" is a prime example of this lack of knowledge. He just said B16 to B18 because like most uneducated fools, those are the only two motors he knows.
@ OP:
Don't jump to the conclusion of B16 or B18 just because those are the only 2 motors of Honda that you know, or rather they aren't even motors, more actually they're a series. There's 2 mainstream B16's and 4 mainstream B18's - and that's just the US, not including the C7's and **** in Europe.
As others have said, if it's a stock '95 EX (no motor swap), USDM, then it has a D16Z6, which is a 1.6L SOHC VTEC motor.
Or you can just take a picture of the engine bay and post it here, they're quite easy to tell (usually).
Old Nov 15, 2007 | 10:01 PM
hondapowerb16a2's Avatar
Default Re: (Syndacate)
wow. what a question. this guy really should just look at the damn block unless he isnt really freinds with the guy
Old Nov 15, 2007 | 10:13 PM
Syndacate's Avatar
Default Re: (hondapowerb16a2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapowerb16a2 &raquo;</TD></TR><TR><TD CLASS="quote">wow. what a question. this guy really should just look at the damn block unless he isnt really freinds with the guy</TD></TR></TABLE>
Wow, good point, my head's so far up my *** right now I completely forgot about the block code.
@ OP:
To the left of the header (when looking at the engine from the front of the car), and down a little (almost to the transmission), there's a slightly extruded flat piece, and engraved into it is the engine code. It'll say something like B16a2 or B18C1, or D15B. That's what kind of block it is (usually the head too unless he did a mini-me swap).
chvathrt
Feb 2, 2008 12:28 AM
d16_civic_07
Dec 15, 2007 05:54 PM
nuttyvtec
Feb 27, 2007 03:21 AM
BoostedB20A
May 28, 2003 04:26 AM
