Suspension & Brakes Theory, alignment, spring rates....
sleeve coilover
Old Nov 15, 2007 | 02:14 PM
boyong07's Avatar
Default sleeve coilover
omni power spring or skunk2? im not planing goin to track just daily and which one can go lower?
Old Nov 15, 2007 | 02:39 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: sleeve coilover (boyong07)
gc.
Old Nov 15, 2007 | 02:51 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boyong07 &raquo;</TD></TR><TR><TD CLASS="quote">omni power spring or skunk2? im not planing goin to track just daily and which one can go lower?</TD></TR></TABLE>
For what car? Civic? Accord? Mustang? Chevelle? 325i?
With a coilover sleeve, the lowest usable ride height for a given spring rate is limited by the damper used, or in some cases, by the point at which the upper control arm hits the frame.
As far as Omni vs. Skunk, they're both 448 lbs-in F/336 lbs-in R for most Civic applications and are nearly identical, so it really doesn't matter which one you choose. Your best bet would probably be to give both companies a call. Buy from whichever company gives you what you feel is the best customer service over the phone.
If you don't have a Civic, Skunk2 spring rates may vary, but only toward the stiffer end of the spectrum. I would not recommend that for a daily driver. Frankly, I wouldn't recommend 448 F/336 R either; I'd prefer Ground Control's default rates of 350 F/250 R for a daily driven street car.
Old Nov 15, 2007 | 03:50 PM
bmoua's Avatar
Default Re: sleeve coilover (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">gc.</TD></TR></TABLE>
if its just a DD, i'm pretty sure you'll want something soft. GC FTW
Old Nov 16, 2007 | 07:45 AM
boyong07's Avatar
Default Re: sleeve coilover (bmoua)
i got civic ex 2000 2dr
maxrpm
Suspension & Brakes
Mar 7, 2005 08:58 PM
LBBP R
Dec 29, 2004 09:34 PM
bloxp1vtec19
Jun 28, 2004 05:40 PM
mr_mbuna
Aug 9, 2003 09:45 PM
