Question about TPS adjusting. Searched
Old Nov 15, 2007 | 09:07 AM
M2B4's Avatar
Default Question about TPS adjusting. Searched
Ok so Ive searched what the appropriate voltage ranges are for the tps. heres what ive come up with:
Helms says .5 close and 4.5 open
H-T says:
.45 open 5 close
my main question is this. when i set close to .45 at open i get like 4.7 when i set close to .5 i get 4.9 open.
i cant get either to fall the same as recommended open and close. Im going to dyno tune saturday wanna make sure its set appropriate. thanks
Old Nov 15, 2007 | 09:14 AM
mgags7's Avatar
See how it says approximately 4.5v at WOT?
4.7V is fine.
Just FYI, the ecu will accept anything from .45 to .55 for 0%, otherwise it will throw a CEL.
Old Nov 15, 2007 | 09:17 AM
M2B4's Avatar
Default Re: (mgags7)
ok i guess ima leave it at .5 close and 4.9 open then. just didnt wanna chance it being wrong and go waste time on the dyno. thanks
Old Nov 15, 2007 | 09:32 AM
mgags7's Avatar
Sounds good chris
If I was still adjusting it, I'd do the .45 and 4.7 WOT. If you've already finished, its not worth re-doing.
Old Nov 15, 2007 | 10:53 AM
98vtec's Avatar
moderator emeritus
thats that i run
Old Nov 15, 2007 | 01:09 PM
94vtirozguy's Avatar
i stuffed around ages adjusting mine..
eventually i got it flickering between .49 and 0.51 at idle.
did not really pay attention to the WOT reading
bnmm
Engine Management and Tuning
Jan 3, 2011 11:13 AM
DonF
10
Sep 14, 2005 03:32 PM
S@nt0s
Feb 10, 2004 11:22 PM
CarbonfiberR
Aug 13, 2002 07:24 AM
EleanoR
Apr 11, 2002 03:44 AM
