How do you hold the shift boot up to the shift knob???? throw out your ideas!
Old Nov 15, 2007 | 09:00 AM
YoungMoneySi's Avatar
Default How do you hold the shift boot up to the shift ****???? throw out your ideas!
hey guys i have had my skunk2 shifter and shift **** on the ride for quite some time now and was thinking of lifting the boot to cover the shifter. any ideas on how to do keep the boot up and eliminate the gap?
thanks guys!
Old Nov 15, 2007 | 09:03 AM
EK-Chris's Avatar
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (YoungMoneySi)
Zip tie worked for me
Old Nov 15, 2007 | 09:06 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (EK-Chris)
hockey tape or electrical tape. just wrap it around a couple of times at the height you want it at, then slide/jam the boot overtop of it
Old Nov 15, 2007 | 09:07 AM
maxvelox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-Chris &raquo;</TD></TR><TR><TD CLASS="quote">Zip tie worked for me</TD></TR></TABLE>
Old Nov 15, 2007 | 09:09 AM
schematicsskater13's Avatar
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (Chris.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. &raquo;</TD></TR><TR><TD CLASS="quote">hockey tape or electrical tape. </TD></TR></TABLE>
Washer, same idea
Old Nov 15, 2007 | 09:10 AM
swifty4u's Avatar
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (schematicsskater1
Yea just take the console off and do it..so you can just place the boot on top of it
Old Nov 15, 2007 | 09:21 AM
is there a way for me to place the nut that screws under the **** under the boot?
Old Nov 15, 2007 | 09:23 AM
VTAC-KAT's Avatar
just use a couple of rubber bands to hold it snug- it works for me
Old Nov 15, 2007 | 10:05 AM
WhiteSlips's Avatar
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (VTAC-KAT)
I took electrical tape and wrapped it around the shifter a bunch of times to get it thick enough to hold the boot up. It's been this way for years, so I reccomend it.
Old Nov 15, 2007 | 10:30 AM
Fabfive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTAC-KAT &raquo;</TD></TR><TR><TD CLASS="quote">just use a couple of rubber bands to hold it snug- it works for me</TD></TR></TABLE>
+1 Works like a charm!
Old Nov 15, 2007 | 11:09 AM
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (Fabfive)
do i need to remove the console or shift **** to do this or can i work with it without taking any of them off?
Old Nov 15, 2007 | 11:22 AM
Chronicsinners's Avatar
zipties and electrical tape here
Old Nov 15, 2007 | 11:28 AM
NickW's Avatar
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (Chronicsinners)
Washer.
Old Nov 15, 2007 | 11:37 AM
SIRIUS's Avatar
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (NickW)
I threaded an upside down hex nut down on the shifter, slipped the boot over and then threaded on my shift ****.
Old Nov 15, 2007 | 01:17 PM
B16B_coupe's Avatar
HRD PKR
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (SIRIUS)
i just let mine go where ever it wanted.. lol didnt really care.. but you can use electrical tape, washers, etc. but you have to remove the consol then install what you want to use then re install the consol..
thats not a bad idea. any of you guys know how the EK9 and DC2 have the shift boot stay up?
Old Nov 15, 2007 | 01:20 PM
AP Kreuzer's Avatar
i use my gf's lil black hair tie thing
Old Nov 15, 2007 | 01:21 PM
Chris.'s Avatar
those little plastic tabs inside the shift boot are 'supposed to', but they dont always work
Old Nov 15, 2007 | 02:17 PM
wes209k's Avatar
ive got a little bit of black foam in mine, works a treat
Old Nov 15, 2007 | 04:24 PM
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (wes209k)
i have a skunk2 dual bend short shifter and a skunk2 shift **** but my shift **** only screws in like half way. it sits loose til i tighten the nut underneath it. i still have a lot of thread left to screw in but it wont. is this common for skunk2 ***** or is it the shifter?
Old Nov 15, 2007 | 04:33 PM
MR Rodgers's Avatar
Duct Tape
Old Nov 15, 2007 | 04:43 PM
BeezInACan's Avatar
I used a bushing from one of my old trucks from my skateboard.
Old Nov 15, 2007 | 07:40 PM
Default Re: How do you hold the shift boot up to the shift ****???? throw out your ideas! (BeezInACan)
Old Nov 15, 2007 | 07:44 PM
roll5104life's Avatar
go to the acura dealership and get there peice that goes with the aspec shift **** i have it on my rsx and it holds it to about a 1/2 from the **** iono if you want it higher or not
Old Nov 15, 2007 | 07:56 PM
Default Re: (roll5104life)
i just wanna know whether there is something wrong or if the skunk2 shifter was designed for ***** to not screw in too much. it doesn't even screw in half way, ijust tried again and it barely screws in. it hangs loose until i tighten it with the nut. i think it is designed like that...dunno if i am feelin that too much...
