'92 Prelude - problem w/ passenger turn signal
It's not THAT big of a deal, but it's still annoying to me... My passenger turn signal on the side of the car (not the front) will not work. When I turn the blinker on the front blinker works, the side blinker does not. I've replaced the bulb (duh) and I've used contact cleaner to try to clean the dirt and grime out... Nothing worked. I took the wiring assembly apart and it looks pretty nasty so I've been searching for a new wiring harness or whatever the item might be called, but have not had any luck. Anybody have an idea where I can get this so-called wiring harness for my passenger side turn signal? Thanks!
Just try and pick one up off of someone parting out a car or from a junkyard.
Have you used a voltmeter yet and figured out if it is getting power at the connector? Do that, then trace it back along the wires some and try again. That will tell you if the connector is the problem.
LSRracing95
Apr 23, 2005 09:36 AM
Dacalac
Jul 11, 2003 03:28 PM
