93CX hatch... catback... do i need a test pipe?
Old Nov 15, 2007 | 07:39 AM
nonvtec92's Avatar
Default 93CX hatch... catback... do i need a test pipe?
i know on my old 97cx i needed a test pipe cause the cat was incorporated into the header.
is my 93 the same way or is there a cat underneith? do i need to buy a test pipe or not?
thanks all!
Old Nov 15, 2007 | 07:42 AM
crazyguy's Avatar
Default Re: 93CX hatch... catback... do i need a test pipe? (nonvtec92)
stock d series engine in your 93? it should be a cat converter if your car is stock. whats the exhaust system set up right now for your 93 cx hatch? any catback system and header (thats made for your car) will bolt on to your stock cat converter and
Old Nov 15, 2007 | 08:32 AM
93CX's Avatar
Default Re: 93CX hatch... catback... do i need a test pipe? (crazyguy)
Yes, you have a removable catalytic converter. If that is what you're asking..
Old Nov 15, 2007 | 08:34 AM
nonvtec92's Avatar
Default Re: 93CX hatch... catback... do i need a test pipe? (93CX)
exhaust is stock on the car...
i was just making sure because on my 97, it did not have a cat under the car. it was built into the header, so that when i bought a catback for it, it was about a foot short after the stock stuff was taken out. so a testpipe was necessary to extend the piping out so the catback would fit.
just wanted to know if i had a cat under the car.
type-GGSR
Mar 4, 2008 09:25 PM
es_squared
Jun 4, 2004 12:02 PM
sxgt
Jul 17, 2001 01:33 PM
