A/C INSTALL
Old Nov 14, 2007 | 07:33 PM
candyman206's Avatar
Default A/C INSTALL
Well...I tried my best searching. It's one of those hard searches because it blocks out A/C. But does someone have a link on what EXACT parts I would need to install a/c into a 99 Civic that never had it in it to begin with. Also, is there a DIY on how to put it in. I pieced some info on it from the search I did like folding down the glove to install the EVAP box and run the lines. But other than that it was short on detail.
Old Nov 14, 2007 | 09:12 PM
714DC4's Avatar
Default Re: A/C INSTALL (candyman206)
I just finished doing an a/c install on my 99 hatch and it was pretty easy. You will need the evap box, hard lines, dryer, condenser, compressor, o rings, hardware, fuses, harness, pulley, belt and button cover.
you can try finding someone on here that is getting rid of their a/c stuff. Any pieces that you can get from anyone on here go to the following:
http://www.hondaautomotivepart...gry5=
You can also use the above site to help piece together you a/c
hope this helps
Ph0t0bug
Dec 30, 2015 09:26 PM
kl3ver
Audio / Security / Video
May 27, 2014 02:49 AM
