AUTO TO MANUAL CONVERSION ???
Old Nov 14, 2007 | 07:29 PM
vtec619's Avatar
Default AUTO TO MANUAL CONVERSION ???
DO MOUNTS FOR AN AUTOMATIC NEED TO BE CHANGED ? I HAVE A 95 EG WITH NO MOTOR AND I JUST BOUGHT A SINGLE CAM VTEC. DO THE MOUNTS NEED TO BE CUSTOM MADE OR CAN I JUST DROP IT IN? I OVERHEARD THAT IF YOU JUST DROP IT IN WITH THE WROUND MOUNTS, YOUR AXLES MIGHT SNAP ? PLEASE HELP !!!
Old Nov 14, 2007 | 08:02 PM
silentcircus's Avatar
Default Re: AUTO TO MANUAL CONVERSION ??? (vtec619)
found this link. it mentions the upper trans mount. hope it helps.
http://www.hondacivicforum.com/m_295187/tm.htm
Old Nov 14, 2007 | 08:03 PM
ejoner's Avatar
You only need to get a custom passenger side upper mount, the front mount also has to be from the manual transmission, everything else just drops in, look in the faq section and you will find a bunch of write ups on auto to manual swaps. Try searching next time.
efcivic92
Sep 21, 2009 10:56 AM
grandtheftlunchbox
May 1, 2008 04:02 PM
preludeboybmw
Nov 22, 2007 09:47 PM
mach0
Nov 5, 2007 03:20 PM
davidcrx89
Apr 21, 2006 10:10 PM
