Request: D15b vtec block picture
Old Nov 14, 2007 | 07:25 PM
Ch3mik's Avatar
Default Request: D15b vtec block picture
I recently had someone do a jdm d15b block /y8 head setup but it wont engage vtec. I know on the normal d15 blocks there is an oil jet that needs to be removed but am not sure if the d15b vtec block has this as well. I figure a picture would be best.can anyone help? or can anyone tell me if it does?
Old Nov 14, 2007 | 07:33 PM
apc123eg's Avatar
Default Re: Request: D15b vtec block picture (Ch3mik)
yes read this might help
https://honda-tech.com/zerothread?id=554053
Old Nov 14, 2007 | 08:40 PM
thenewguy93eg's Avatar
Old Nov 14, 2007 | 09:16 PM
ejoner's Avatar
Default Re: Request: D15b vtec block picture (thenewguy93eg)
The jdm d15b motor already has vtec and is equipped with a z6 head (92-95 sohc vtec) The y8 head should be a direct fit with absolutely no mods other then swapping over a few obd2 components. What ecu are you running? Oil level? everything plugged in? Cel's?
Old Nov 15, 2007 | 03:00 AM
Ch3mik's Avatar
Default Re: Request: D15b vtec block picture (ejoner)
this is a JDM D15B VTEC block, not a USDM D15b NONVTEC block peeps.
but yea, its runnin a p28 and all is plugged up. seems like vtec isnt hittin :/
Old Nov 15, 2007 | 06:20 AM
pgpbubble's Avatar
Default Re: Request: D15b vtec block picture (apc123eg)
Its a single cam; it doesn't really hit.
Old Nov 16, 2007 | 02:32 PM
Ch3mik's Avatar
Default Re: Request: D15b vtec block picture (pgpbubble)
wel true but it falls on its faceafter 5k. I know how its supposed to run but its not runnin right. hm.
Old Nov 16, 2007 | 03:29 PM
marquisdee1018's Avatar
You want to try out the p08 I have in my car?
Old Nov 16, 2007 | 05:30 PM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble &raquo;</TD></TR><TR><TD CLASS="quote">Its a single cam; it doesn't really hit. </TD></TR></TABLE>
hmmmm.. mine hits.... mine hits VERYYYYYYYY nice infact..
Old Nov 18, 2007 | 10:18 PM
Ch3mik's Avatar
Default Re: Request: D15b vtec block picture (JDM_SOHC)
hm
Old Nov 18, 2007 | 10:29 PM
51-50ej7's Avatar
check your timing
Old Nov 19, 2007 | 12:23 PM
Ch3mik's Avatar
Default Re: Request: D15b vtec block picture (51-50ej7)
hm. i should.
Old Nov 19, 2007 | 02:16 PM
Bejita's Avatar
Wrong ECU buddy. You need the P08 ecu for that engine to work right.
Old Nov 20, 2007 | 03:58 PM
Default Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">Wrong ECU buddy. You need the P08 ecu for that engine to work right.</TD></TR></TABLE>
That's what I was thinking. I'm running a P08 with my d15b. Hey Ch3mik, I'll be free this weekend if you want use mine ans see if that's the problem.
Old Nov 20, 2007 | 08:41 PM
Black-Ty [EG6]'s Avatar
Default Re: (marquisdee1018)
y would u need a ecu 2 match the block?
wouldn't the p28 work fine?
Old Feb 1, 2008 | 06:45 PM
Ch3mik's Avatar
Default Re: (Black-Ty [EG6])
gay motor
Old Feb 2, 2008 | 06:07 PM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Ty [EG6 &raquo;</TD></TR><TR><TD CLASS="quote">]y would u need a ecu 2 match the block?
wouldn't the p28 work fine?</TD></TR></TABLE>
my d15b has always been on p28, an has ran great.. even before turbo an chipped the p28... now it runs even better..
Old Feb 2, 2008 | 09:11 PM
Jonknee's Avatar
Default Re: (JDM_SOHC)
Dont need a p08, Im running a p28 and vtec is quite noticeable actually.
Old Feb 2, 2008 | 09:14 PM
ejoner's Avatar
Default Re: (Jonknee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonknee &raquo;</TD></TR><TR><TD CLASS="quote">Dont need a p08, Im running a p28 and vtec is quite noticeable actually.
</TD></TR></TABLE> +1 I'm also running a p28 once I got timing dead on the motor runs perfectly.
omnijdm
Feb 8, 2012 09:16 AM
Slo Honda Driver
Aug 3, 2005 06:11 PM
See65
14
Mar 29, 2005 05:01 PM
