Si springs vs. Dx springs and other OEM spring questions
Is there any difference at all? What springs that are of slightly stiffer rates, or shorter length will fit on my OE struts (from a 90 Dx sedan)? Thanks.
all stock springs are the same. if you want to go stiffer you have to go aftermarket.
i'm pleased with my eibach pro kit, its not too stiff for passengers but not too soft to handle either, and not too low.
and if you want stiffer springs ditch your stock shocks, as you will be bouncing all over the place with stock shocks and stiffer springs.
a rear sway bar with the stock suspension makes a big difference (unless you already have one)
supermegaawesome
Jun 20, 2009 05:31 PM
