Used Aircraft remover to remove paint from rims......... Yes i used the search botton.
Old Nov 14, 2007 | 01:31 PM
itsmedavid's Avatar
Default Used Aircraft remover to remove paint from rims......... Yes i used the search botton.
After i search the forums on how to go about to remove the paint from rims i finally used aircraft remover. I used the aircraft remover because when i paint my rims it came out bad so i wanted to redo them again (Used around 1 coat of primer and 3 coats of black paint). However after i sprayed it on i wait about 30 minutes before i start to spray it down with water. The aircraft remover did remove the paint a little but it came out like tar but some area's it didnt do anything. Should i have waited longer before i washed it down or what?
Old Nov 14, 2007 | 02:30 PM
SjCiViCHB's Avatar
Default Re: Used Aircraft remover to remove paint from rims......... Yes i used the search botton. (itsmedav
Did you buy the spray on type? or is the kind that you have to apply on? The spray can aircraft remover isn't really that strong, so you'll need to give it more time to penetrate. Get the kind in a can thats not a spray & give it some time to eat thru the paint. Also you should clean your wheels a little bit before using the aircraft remover.
Old Nov 14, 2007 | 03:30 PM
itsmedavid's Avatar
Ill give that a try thanks
Old Dec 13, 2007 | 09:16 PM
keviiinnnnn's Avatar
i just did mine today
add a generous amount and let it set for about 30 mins then take a wire brust and it will take it all off
Old Dec 14, 2007 | 07:37 AM
Genuine Rolla's Avatar
It also depends heavily on the tempurature that your in. I did mine when it was 40-50's and It didn't work all that great.
Has to be atleast 60+ IMHO.
Old Dec 14, 2007 | 04:26 PM
vsmhatched's Avatar
Default Re: (Genuine Rolla)
yeah....temp has a big deal with how aircraft stripper works...it hates cold weather for sure
Old Apr 9, 2008 | 12:39 PM
McDonagh's Avatar
will it ruin the tires????, jw, but i assume it would
Old Apr 9, 2008 | 05:18 PM
Coal_forge's Avatar
Yep it will break down the rubber on the tires. I used steel wool and aircraft stripper for my wheels. To get all the small stuff left over I used carb cleaner.
Do wear gloves for this. I used leather because this aviation stripper will dissolve latex and nitrile gloves.
Old Apr 9, 2008 | 07:41 PM
McDonagh's Avatar
thanks man, saved my tires
Old Apr 9, 2008 | 08:05 PM
88civic's Avatar
scotch brite or any thing abrasive will help!!!
think of what a flat surface looks like then what a surface will look like with scratches on it the one with scratches will allow the stripper to penetrate better!! more surface it can touch!!!
send2artem
Oct 15, 2010 06:23 AM
tpot90
Feb 13, 2009 02:38 PM
kmeng
Feb 9, 2009 11:43 AM
cbmprelude
Dec 20, 2006 08:52 AM
SiB16A
Feb 25, 2005 10:38 PM
