Which d15b?
Old Nov 14, 2007 | 01:07 PM
LIMITLESS22's Avatar
Default Which d15b?
I have a d15b thats been sitting in my garage that I got from some kid many years ago. He said his uncle got it and it was a JDM d15b. I was going to do the swap and he brings me a bare head and block (still attached). We ended up putting in a dohc ZC instead.
Question is how is it possible to tell which version engine it is. I cant find many people that know the answer. (Actually none thats why Im asking).
Are there certain serial number sequences?
Can I tell if I pull the valve cover?
Somebody help this things in my way and I would like to build it if its worth it.
Old Nov 14, 2007 | 01:11 PM
crazyguy's Avatar
Default Re: Which d15b? (LIMITLESS22)
it should have a stamp at the engine block that says b15b or ..and to tell if the engine is jdm or not.. for example.. b16a stamped on the block is jdm.if u see b16a2 or b16a3 it is usdm...with a number digit at the end is usdm engine.
to rebuild the engine or not. it depends on what do u want to do with it in the future..to boost it or just make it a reliable daily drive..
Old Nov 14, 2007 | 01:13 PM
Bejita's Avatar
If it only says D15B it's a JDM 1.5 liter VTEC. If it says anything else after the B. It's USDM and non VTEC.
Old Nov 14, 2007 | 01:18 PM
97Ej6mike's Avatar
Default Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">If it only says D15B it's a JDM 1.5 liter VTEC. If it says anything else after the B. It's USDM and non VTEC.</TD></TR></TABLE>
OBD1 or the less common OBD2 version?
Old Nov 14, 2007 | 01:20 PM
Default Re: Which d15b? (crazyguy)
yeah its definatly JDM. Only says d15b.
Oh and its also got the silver valve cover.
I just want to know if its the 130 version or not.
I might build it and put it into a track car.(not drag)
Bejita's Avatar
Both only say D15B as far as I know.
Old Nov 14, 2007 | 01:24 PM
crazyguy's Avatar
JDM D15B Vtec SOHC 92-95 Honda Civic
Code: D15B
Displacement: 1493
Power: 130@6800
Torque: 14.1 kg/m@5200
Compression: 9.6:1
Cam Design: SOHC
VTec: YES
Car: 92-95 Honda Civic
Old Nov 14, 2007 | 01:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">JDM D15B Vtec SOHC 92-95 Honda Civic
Code: D15B
Displacement: 1493
Power: 130@6800
Compression: 9.6:1
Cam Design: SOHC
VTec: YES
Car: 92-95 Honda Civic</TD></TR></TABLE>
So your saying there is only 1 JDM d15b VTEC?
Old Nov 14, 2007 | 01:29 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LIMITLESS22 &raquo;</TD></TR><TR><TD CLASS="quote">
So your saying there is only 1 JDM d15b VTEC?</TD></TR></TABLE>
jdm 96+ civic also have d15b jdm vtec engine and if your d15b comes with original tranny..there should be a sticker or badge on the tranny with serial number that u can research and u will be able to tell which year it was manufactured.but u said it comes with a silver valve cover..as i remember ..it is 96 and up d15b obd2
Old Nov 14, 2007 | 01:31 PM
Is the 96+ JDM still 130?
97Ej6mike's Avatar
there is also the OBD2, the lesser known and less common (but unique) version.
D15B (with 3 stage VTEC)
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Fagio Vi
Displacement : 1493 cm3
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.6:1
Power : 130 hp @ 6800 rpm & 102 ft·lbf @ 5200 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-2 MPFI
I know allot about this motor being i work with one.
It utilizes the P2J ecu which is very hard and rare to find.
Old Nov 14, 2007 | 01:33 PM
jdm 96+ civic also have d15b jdm vtec engine and if your d15b comes with original tranny..there should be a sticker or badge on the tranny with serial number that u can research and u will be able to tell which year it was manufactured</TD></TR></TABLE>
Problem is no trans. I only got the long block stripped. not even a vtec solenoid.
Only reason I hold on to it is hope. Its got the silver valve cover with VTEC and its stamped d15b.
Old Nov 14, 2007 | 01:35 PM
crazyguy's Avatar
yeah obd2 ..96 up d15b also has 130 HP
Old Nov 14, 2007 | 01:39 PM
95 honda8's Avatar
HP got ya, thanks
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">there is also the OBD2, the lesser known and less common (but unique) version.
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
It utilizes the P2J ecu which is very hard and rare to find.</TD></TR></TABLE>
Is the engine different with the 3-stage VTEC or is it just different engagement points initialized by the ecu?
Basically it is the 130 version is what you guys are saying.
Old Nov 14, 2007 | 01:40 PM
Default Re: Which d15b? (95 honda8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 honda8 &raquo;</TD></TR><TR><TD CLASS="quote"> HP got ya, thanks</TD></TR></TABLE>
You know what Im talking about!
Old Nov 14, 2007 | 01:41 PM
Bejita's Avatar
The 3 stage VTEC is weaker compared to the OBD1 version. 3 stage VTEC was invented strictly for fuel conservation. Does the head have 2 VTEC silenoids?
Old Nov 14, 2007 | 01:46 PM
It doesn't have any solenoids. its a bare longblock. Is that the only way to tell?
Old Nov 14, 2007 | 01:48 PM
Bejita's Avatar
A long block should still have the VTEC solenoids on it. They are bolted to the head.
Old Nov 14, 2007 | 01:51 PM
Dude its completly bare. no sensors, no manifolds, no vtec solenoids, nothing.
Old Nov 14, 2007 | 02:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">The 3 stage VTEC is weaker compared to the OBD1 version. 3 stage VTEC was invented strictly for fuel conservation. Does the head have 2 VTEC silenoids?</TD></TR></TABLE>
What is 3stage vtec?
So will it not perform correctly if I use a pm6?
Old Nov 14, 2007 | 02:48 PM
Bejita's Avatar
Default Re: (LIMITLESS22)
So will it not perform correctly if I use a pm6?</TD></TR></TABLE>
No way.......It's damn near imposible to get stage 3 VTEC to work properly. Even with a maped USDM ecu. You have to get the correct JDM ecu and they are rare as hell. Not even worth it.
Old Nov 14, 2007 | 02:53 PM
So back to the original Q.
How can I tell which engine it is.
Theres got to be some way other than just the solenoids.
Im down to open the engine up. I just dont know what the difference is and no one seems to be able to tell me.
Is the rocker shaft different in some way? Different oil passages or solenoid location?
Old Nov 14, 2007 | 06:23 PM
So basically nobody knows the difference between a d15b vtec and vtec-e?!
As far as the internals go.
Old Nov 14, 2007 | 06:55 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">A long block should still have the VTEC solenoids on it. They are bolted to the head.</TD></TR></TABLE>
They are removable.
No way.......It's damn near imposible to get stage 3 VTEC to work properly. Even with a maped USDM ecu. You have to get the correct JDM ecu and they are rare as hell. Not even worth it.</TD></TR></TABLE>
Im running one with a P2P ecu and No cel's, recently passing NJ state inspection without any trouble. Yes they are hard to find, but they exist.
