89-91 DX OR SI Tranny which will yield better fuel mileage?
Old Nov 14, 2007 | 09:42 AM
jwbnavy's Avatar
Default 89-91 DX OR SI Tranny which will yield better fuel mileage?
Am considering doing a dx to si tranny swap in my commuter for better mpg's. Did a search but no one mentions this, just that the si tranny is more fun to drive. I travel a lot with this car and want lower rpm at highway speed. Any suggestions?
Old Nov 14, 2007 | 09:44 AM
90efhatch's Avatar
if you want lower rpm's at highway speeds stick with the DX. I cant remember what my si trans did at highway speeds but my zc trans runs around 3500 at 70. I think that the DX trans is at 2500 at 60 or so.
Old Nov 14, 2007 | 09:46 AM
wiZCo's Avatar
Stouts 'n' Scotch
Definitely the DX.
Old Nov 14, 2007 | 09:52 AM
jwbnavy's Avatar
Default Re: (wiZCo)
Ah good to know I was going to do the swap. I think my trans is grinding but im not sure what a grinding noise sounds like. Its not that loud and it comes and goes. lifted front end into the air and spun wheel and heard a slight clicking. Is that grinding?
Old Nov 14, 2007 | 09:53 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (jwbnavy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwbnavy &raquo;</TD></TR><TR><TD CLASS="quote">Ah good to know I was going to do the swap. I think my trans is grinding but im not sure what a grinding noise sounds like. Its not that loud and it comes and goes. lifted front end into the air and spun wheel and heard a slight clicking. Is that grinding?</TD></TR></TABLE>
Probably the input shaft bearing.
Old Nov 14, 2007 | 09:56 AM
90efhatch's Avatar
Input shaft bearing is only $25 from the dealer. It will cost to get it installed if you cant do it yourself.
jwbnavy's Avatar
Default Re: (wiZCo)
I will replace it this weekend, cheaper than doing the whole trans!
Old Nov 14, 2007 | 09:59 AM
jwbnavy's Avatar
Thanks for the idea I will let you know, I kinda felt it was that but am new to the honda car world. I am a motorcycle guy. My brother left me this car when he died and now im hooked. i want to redo everything.
Old Nov 14, 2007 | 03:40 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwbnavy &raquo;</TD></TR><TR><TD CLASS="quote">I will replace it this weekend, cheaper than doing the whole trans!</TD></TR></TABLE>
It depends. You can often get a whole DX transmission for free. I know I've given them away.
Old Nov 19, 2007 | 10:36 PM
FOMULA91's Avatar
Default Re: 89-91 DX OR SI Tranny which will yield better fuel mileage? (jwbnavy)
I sold my HF transmission to a guy who was going to change the Si 5th with the HF.
Old Nov 19, 2007 | 10:44 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: 89-91 DX OR SI Tranny which will yield better fuel mileage? (FOMULA91)
you can have the best of both worlds with the si trans.. you can buy an si trans and swap the hf 5th gearset into it, so that your 1-4 gears are unchanged and fun to use, and the 5th is the no frills economy cruising gear.
I have my trans set up right now with a 4.9 final drive with a .702 5th gear and i consistently get about 34 mpg highway, and i can still accelerate very quickly from first through 4th.
Old Nov 19, 2007 | 11:07 PM
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwbnavy &raquo;</TD></TR><TR><TD CLASS="quote">Am considering doing a dx to si tranny swap in my commuter for better mpg's. Did a search but no one mentions this, just that the si tranny is more fun to drive. I travel a lot with this car and want lower rpm at highway speed. Any suggestions?</TD></TR></TABLE>
all depends on how fast you drive.
DX 4th = Si 5th, no gains at 45-50 mph.
CRX_Control
Jan 16, 2005 08:18 AM
tysf
13
Jun 25, 2003 03:15 PM
maximedx
15
Oct 12, 2002 06:46 AM
serious
14
Jul 17, 2002 03:31 AM
