Faster Power Steering Rack Ratio For a 99 Hatch
Old Nov 14, 2007 | 07:05 AM
Long Grain Wild's Avatar
Default Faster Power Steering Rack Ratio For a 99 Hatch
I've got a 99 Hatch with power steering and I would like to keep the power steering but would like to decrease the rack ratio a little to make the steering a little quicker.
According to the FSM, I've currently got a Ratio = 17.7 : 1 with 3.6 turns lock to lock. I'm not looking for go-kart 8:1 or anything like that... Just something maybe 10-25% faster than stock.
Are all the 6G racks the same ratio for the years/models?
Will any of the Integra racks fit my 99 hatch?
Can I swap guts from an Integra rack into my rack?
Quaife won't work. I have power.
Old Nov 14, 2007 | 07:12 AM
Bazza's Avatar
yea id like to know if i could get my ratio down too on my del sol is there a site that we can get these at??? (id like go cart style haha)
Old Nov 15, 2007 | 07:00 AM
Default Re: Faster Power Steering Rack Ratio For a 99 Hatch (Long Grain Wild)
So no options for the 6G? Contradictory information is rampant. Read up:
https://honda-tech.com/zerothread?id=1317231 - Litterbox put a quaife in a non-power 5G
https://honda-tech.com/zerothread?id=1881245 - Discussion about the lack of options for a tighter ratio PS 6G
https://honda-tech.com/zerothread?id=1656620 - Bense installing Teg PS rack into 5G
https://honda-tech.com/zerothread?id=1618353 - MasterKwan says he put teg guts into 6G rack
https://honda-tech.com/zerothread?id=1947158 - NOFX talks about part numbers for racks for different years
https://honda-tech.com/zerothread?id=1756670 - Rodney says the Si is the same ratio as the others
https://honda-tech.com/zerothread?id=1712864 - Maybe you could swap 5G subframe into 6G and then you can use teg rack
Old Nov 27, 2007 | 03:21 PM
NOFX's Avatar
H-T White Ops
Just like you mentioned, the factory service manual has the stock info. Even for cars with power steering too.
Manual Steering
Type: Rack and pinion
Overall Ratio: 20.3
Turns, Lock-to-Lock: 4.1
Power Steering
Type: Power assisted, rack and pinion
Overall Ratio: 17.7
Turns, Lock-to-Lock: 3.6
It's all right there on page 3-22 in the '96-'99 FSM.
I don't know enough about power and non-power steering though, so I couldn't tell you if there's someway to make a hybrid with a shorter ratio since the power steering cars are the ones with the shortest ratio.
Perhaps this will bump the thread so someone with experience can post an opinion.
Old Nov 28, 2007 | 05:41 AM
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">power steering cars are the ones with the shortest ratio.
Perhaps this will bump the thread so someone with experience can post an opinion.</TD></TR></TABLE>
That's the problem in a nutshell... It seems that I've already got the fastest power rack available for a 6G civic and nobody has ever done any better than that??? At 17.7 : 1 with 3.6 turns lock to lock??? With all the chatter about people wanting faster ratios, there's absolutely no options out there to do any better than that? Only option is a ratio multiplier to end up with a go-kart? Seems hard to believe.
Options:
<U>1) Install Quaife rack</U> - Won't work. Quaife is for non-power only. I've got power and want to keep it.
<U>2) Use Si subframe and rack</U> - Won't work. According to the part numbers all 6G racks are the same including the Si.
<U>3) Drop in an Integra rack</U> - Won't work. Teg rack only fits 5G Civic. Doesn't fit 6G Civic.
<U>4) Swap subframe from a 5G into my 6G</U> - Not sure. Big job and can't figure out for sure if it even fits.
<U>5) Swap Teg rack guts into my 6G rack</U> - Not sure. I've been to a boneyard and have compared the Teg rack to the 6G Civic rack and there are some non-trivial differences in the guts. The biggest difference I found was that the Teg rack is a couple inches wider than the 6G Civic. Might cause a problem... might not. Changes the tie rod angles and you might run out of alignment adjustment. Depends on the design of the rest of the parts.
All the people with 6G Civics looking for faster steering and nobody has come up with any other alternatives???
And thanks for the bump. I'm such a thread killer....
Old Jun 20, 2008 | 02:46 PM
STN_Pat's Avatar
Default Re: (Long Grain Wild)
need options
Old Jun 20, 2008 | 03:24 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (STN_Pat)
Back from the dead bump
Old Oct 4, 2009 | 01:15 PM
Player_One's Avatar
Default Re: (NOFX)
Options:
4) Swap subframe from a 5G into my 6G - Not sure. Big job and can't figure out for sure if it even fits.
#4 will work. There are a bunch of K-series guys using an EG subframe in an EK. I can't comment on how the rear engine mount would work with a B/D-series though...
senate422
Nov 12, 2011 05:44 PM
honda wrc
Feb 23, 2010 06:38 PM
bouncingon8
Aug 23, 2009 09:55 AM
a10secstreetcar
Apr 6, 2007 12:09 PM
waruy0i92Si
Jun 27, 2005 03:10 PM
