golden eagle sandwich adapter $90
Old Nov 13, 2007 | 08:06 PM
electric_rex's Avatar
Default golden eagle sandwich adapter $90
carbon fiber f1 $90 style mirrors. super light design. beautiful weave.
turbo setup $2000
turbo hasnt been ran since rebuild
-tial 40mm waste gate never seen exhaust gas
-anodized blue
-garrett t3/60-1 turbo
-.70 compressor side
-.63 exhaust side
-360 thrust bearing
-just rebuilt by stp(savannah tire performance) due to previous shaft play
-intercooler (never seen boost)
-32in end tank to end tank
-12 tall core
-3in thick
-flat black "sleeper"
-blitz dd blow off valve (used)
-golden eagle silver vaccuum manifold w/ fittings
-gm 3bar map sensor
Mfactory oil relocation oil cooler kit $235
-used for 500 miles
Z10 oil catch can setup $130
-the can, black box block off fitting and vaccuum fitting were $120 new
-the ss line and fitting are $75 new
precision 880cc fuel injectors $250
-new used
hasport ef chassis b series mounts $235
-will include hasport shift linkage for $65 extra
-comes with the ss line for ls/vtec
autometer BOOST, OIL PRESSURE, EGT, WATER TEMP AND RPM GAUGES $300
autolock hood pins $80 each
- I have two sets. one with locks and one without.
set of 4 rota RB rims $850
-30mm offset
-never been mounted bought for $915 shipped
-new on falker azenis 205/50/15
ls/vtec motor $2000 negotiable
cost about 2800 to build JAY from asian automotive savannah build the motor
-gsr crank
-eagle gsr rods
-b18a block 81.5mm over bore
-ross 9:1 turbo pistons
-arp head studs
-b16 head
-itr cams
-itr valvetrain
-oem bearings
-comes with dizzy
-oil pan tapped for oil return from turbo
any questions contact me at 912 492 2969 name is josh.
Old Dec 9, 2007 | 07:08 PM
Default Re: golden eagle sandwich adapter $90 (electric_rex)
bump
electric_rex
Dec 31, 2007 08:21 PM
electric_rex
Nov 20, 2007 05:55 PM
electric_rex
Nov 19, 2007 09:51 AM
electric_rex
Nov 19, 2007 09:49 AM
electric_rex
Nov 14, 2007 10:13 PM
