Mfactory oil relocation oil cooler kit $235
carbon fiber f1 $90 style mirrors. super light design. beautiful weave.
turbo setup $2000
turbo hasnt been ran since rebuild
-tial 40mm waste gate never seen exhaust gas
-anodized blue
-garrett t3/60-1 turbo
-.70 compressor side
-.63 exhaust side
-360 thrust bearing
-just rebuilt by stp(savannah tire performance) due to previous shaft play
-intercooler (never seen boost)
-32in end tank to end tank
-12 tall core
-3in thick
-flat black "sleeper"
-blitz dd blow off valve (used)
-golden eagle silver vaccuum manifold w/ fittings
-gm 3bar map sensor
-used for 500 miles
Z10 oil catch can setup $130
-the can, black box block off fitting and vaccuum fitting were $120 new
-the ss line and fitting are $75 new
precision 880cc fuel injectors $250
-new used
hasport ef chassis b series mounts $235
-will include hasport shift linkage for $65 extra
golden eagle sandwich adapter $90
-comes with the ss line for ls/vtec
autometer BOOST, OIL PRESSURE, EGT, WATER TEMP AND RPM GAUGES $300
autolock hood pins $80 each
- I have two sets. one with locks and one without.
set of 4 rota RB rims $850
-30mm offset
-never been mounted bought for $915 shipped
-new on falker azenis 205/50/15
ls/vtec motor $2000 negotiable
cost about 2800 to build JAY from asian automotive savannah build the motor
-gsr crank
-eagle gsr rods
-b18a block 81.5mm over bore
-ross 9:1 turbo pistons
-arp head studs
-b16 head
-itr cams
-itr valvetrain
-oem bearings
-comes with dizzy
-oil pan tapped for oil return from turbo
any questions contact me at 912 492 2969 name is josh.
turbo setup $2000
-anodized blue
-.63 exhaust side
-360 thrust bearing
-12 tall core
-3in thick
-gm 3bar map sensor
-used for 500 miles
-new used
-30mm offset
-gsr crank
-eagle gsr rods
-arp head studs
-b16 head
-itr cams
-itr valvetrain
-oem bearings
-comes with dizzy
theres nothing wrong with the cooler at all or the lines, no pin holes or major rock dents of the sort..
mfactory oil cooler 235.00 shipped? pm me if you will take my offer. i'll paypal 245.00 shipped?
Bringing this thread back to life. Sent you a PM on Friday and you responded saying send you the money through paypal. Money was sent Friday and I still haven't heard from you. Please give me some info.
electric_rex
Dec 9, 2007 07:11 PM
electric_rex
Southeast (Sales)
Nov 20, 2007 03:28 PM
